Comp Cam OR 2002 LS6?
Old Jun 29, 2003 | 08:12 PM
Default Comp Cam OR 2002 LS6?
I have seen that the Comp 212/218-114 gives our trucks about 40-50 hp and the LS6 gives us about 30 hp. I was wondering which one would be the best with a Radix Magnacharger System and a Yank 3200? Also how much torque does the comp cam give you and what is the power band? If you have any other ideas that would be better please give me some insight. TIA Brandon
Old Jun 29, 2003 | 08:41 PM
Banned
Default Re: Comp Cam OR 2002 LS6?
the comp cam would be pretty good with the charger since it has a pretty good split, but so does the ls6 cam, the comp cam will probably give you more power and a pretty broad powerband as well. with the converter you would have a beast with that cam and the charger. how much boost are you running?
Old Jun 29, 2003 | 09:13 PM
Thanks for the info Slow.
I don't have the charger yet. I am just devising a plan to have one hell of a street truck. I would like to see around 9 psi when I get it, by using a 3.0 inch pulley.
Old Jun 29, 2003 | 09:19 PM
Banned
sounds like a good plan man, i'm thinking of going ahead and finishing my 6.0 heads/cam motor and then sometime later in the year nov/dec maybe downsizing the cam and going with a D1-SC or something like that for some boost. ofcourse a heads cam nitrous motor is always fun too.
Old Jun 29, 2003 | 10:20 PM
3.0" pulley gives about 9 1/2lb boost I think Flyer is running a LS6 cam and heads with his Radix setup.I'm running stock heads and SLP rockerarms on mine.
Old Jun 30, 2003 | 02:22 AM
The LS6 cam will give more boost because of the bigger split. what is the lift on the comp cam
ARC
57
Feb 21, 2022 10:54 AM
low2001gmc
Jul 23, 2015 05:10 PM
Offroadunleashed
Jul 20, 2015 02:25 PM
projectnightcrawler
Jul 19, 2015 11:30 PM
4B11T
Jul 13, 2015 03:48 PM
