Comp Cam
Old Feb 25, 2004 | 06:40 AM
Flem's Avatar
Flyer, what cam is it that you have? the 212/218 high lift? I'm running the 02' LS-6(204/218) @.050" and .551/.547) and I thinking of doing a 5.7 or 6.0 this spring and summer. so I kind of shopping cams too.
Old Feb 25, 2004 | 07:29 AM
12sec.5.3's Avatar
Any of you guys running that .216/.220 .525/.532 cam have any numbers at the track or dyno?
Old Feb 25, 2004 | 08:08 AM
BigTex's Avatar
I'm pretty sure Flyer and RED2K both have the 216/220 .53x lift cam.
Old Feb 25, 2004 | 09:43 AM
Flyer's Avatar
What he said .. 114+2 I think
Old Feb 25, 2004 | 11:54 AM
Flem's Avatar
did you lose any low-end? the ls-6 cam felt like it lost some to about 3k. I really need a converter the one in the burbs stall @ 1700 and will only flash to 1800-1900 rpm so its not very quick out of the hole. the ls-6 cam was put in w/ ls-6 timing chain and I 've heard they are 2 degrees retarded so its not helping low and mid.
I thinking maybe a custom cam w/ rpm lobes, 208-212 intake and 216-218 ex. w/ 115 LSA +2,3
Old Feb 25, 2004 | 12:02 PM
BigKID's Avatar
Can't you get the 216/220 in the high lift XER lobes like the 212/218? That cam on a 114+2 is what I am looking at doing if I can get a set of heads.
Old Feb 25, 2004 | 12:26 PM
Flyer's Avatar
Flem .. I can't compare it to stock with the blower ... the cam was done same time the blower was put on. Sorry ...
Old Feb 25, 2004 | 12:45 PM
12sec.5.3's Avatar
I see you got a new best et. I like. What you done? What is "XER" lobes?
Old Feb 25, 2004 | 12:53 PM
BigKID's Avatar
Just a small cam (2k vette cam), new tranny, good bottle pressure and cool air. I am hoping for even better this comming sunday if everything goes well. Haveing some exhaust work done to fix a previous hack job on thursday.
btw.. let me know if you yank that 212/218 out. I may take it off your hands.
Old Feb 25, 2004 | 02:10 PM
12sec.5.3's Avatar
Hey man, what do you have your shift points set at? pm me and give a lil more info on how that cam is?
Originally Posted by RED2K
Them cam wil work fine but I would go with something with a bit more lift if I were to do it again. I lost quite a bit bottum end with it but since then have added a stall and gears. I have over 35k miles on this cam and the only issues I have is tuning ones. This cam needs a good tune for sure to get the gains it is designed for. IT isnt a monster by any means but big enough to need a tune
