Comp Cam
Old Feb 25, 2004 | 09:04 PM
  #21
Originally Posted by 12sec.5.3
Thinking about doing a cam swap. Currently I have the comp. .212/.218 .521/.528
I'm thinking about stepping up to the comp. .216/.220 .525/.532
I wanna keep the same shift points, just make more top end. What do you think?
12.8 cam only 5.3
sure would like a copy of your program. Did you have idle problems with the 212/218 ? I installed 216/220 and do. I'm running comp cams 216/220 561/564 I like it it pulls good up high 4500-6200 ,did require spring change.
Old Feb 25, 2004 | 09:29 PM
  #22
StupidFast's Avatar
I would really suggest a bigger jump in cams. I have had both and wished both times to go bigger. Have you thought about a TR224/224@112?
Just my opinion.
Old Feb 25, 2004 | 10:33 PM
  #23
RED2K's Avatar
I would do what stupid fast said. I would say it would be worth the jump from what you have now to that. Since you have head work done i would go bigger in lift and duration.
Old Feb 26, 2004 | 09:43 AM
  #24
12sec.5.3's Avatar
Well don't you think i'd have to rev it a little high with theTR224/224. I'm already shifting at 6200, 6350, rev limit at 6600. Keep in mind i have 95000 on the clock and only have ARP rod bolts in the bottom. Really don't wanna sling it apart right now. I might go to thunder today or give them a call.
low2001gmc
Jul 23, 2015 05:10 PM
Ammadien
Jul 22, 2015 08:50 PM
WICK3DxGATA
Jul 21, 2015 06:59 PM
projectnightcrawler
Jul 19, 2015 11:30 PM
4B11T
Jul 13, 2015 03:48 PM
