comp 216/220?
#61
it really depends on which side the restriction is on. intake or exhaust.
-stock heads
-stock intake manifold
-cold air intake
-long tube headers
-aftermarket exhaust
-no cats
With that there, which side would you consider the restriction? The intake or the exhaust?
reverse split cams work best in...
The LS1?
a motor can't get more in, if it can't get it out.
#62
Originally Posted by stealth03ss
so will the added lift move the powerband upwards at all? got your pm mark...dude, if i only had some cash
duration has more to do with where the powerband is.
#63
Originally Posted by SportSide 5.3
Example:
-stock heads
-cold air intake
-long tube headers
-no cats
-stock heads
-cold air intake
-long tube headers
-no cats
Motors with a restricted intake?
The LS1?
The LS1?
But we can get it out, can we not?
#64
back on the reverse split cam thing. read this current thread.
https://ls1tech.com/forums/showthread.php?t=222222 i'll pull a quote right out of it.
Originally Posted by gomer
I've had 15 cams in my car and the worst ones were reverse splits. I would never waste my time installing another one.
#65
just restating marc_w quote. mark can you explain a little more the differences you are noticing with the swap?
Originally Posted by marc_w
My only guess would be that we really don't need the help on the intake side.
I ran that 220/220 cam, and the powerband was just too high.
Actually, I think something just clicked...
It was my understanding that more intake duration brings the entire powerband up in RPM's. I don't think the intake lobe is like the exhaust lobe, in that the exhaust lobe 'helps' the exhaust system in the truck...... I think it's more like the intake lobe is it's own entitiy, seperate from the physics of the intake system.
Not stating facts, just taking a stab at this.
#66
in response to this thread, VHP has added more to the tech and tunign page. this should help you understand more as to why they do the things they do. and it works.
http://www.vincihighperformance.com/...20PAGE%20.HTML
#68
the exhaust side of the stock heads. remember you posted the flow percentages of the 5.3 head. in the .200-.500 range is was never over 75%. so you would need to add more to the exhaust side of the cam to help the head out.
if that was the case, then why is the LSx intake only giving 10hp?
So you feel b/c the FAST manifold isn't making much power over GM's that the intake is not a restriction? Why are the carb, single and dual plane setups gaining so much? Its the design.
so you would need to add more to the exhaust side to compensate
#69
I agree that the exhaust side of the head is the restriction. With the exhaust system on and the intake manifold in place, the percentages would look alot different.
At what rpm? Have you tested this? I believe a test in Car Craft showed +21rwhp at 6600rpm and moved the tq curve up 1000rpm on a 5.3L w/ the Fast intake.
Obviously you feel the exhaust is the restriction, but your looking at the head flow numbers without a intake manifold and exhaust system installed. Finding the flow numbers with the bolt ons in place would show a much different ratio.
the head flow numbers are without any addons. this is to isolate what the head flow is. there are too many variables when adding aftermarket intakes and exhausts. so, yes the numbers will change. but that's because of the components own restriction. not the head. if the head can flow 250cfm, but the intake can only flow 200 cfm, that's the intakes fault. not the head. now, replace it with an intake that can flow 300 cfm. now the intake port of the head is the restriction. but now we get into air flow velocity. which is another thread someday.
#70
now onto the next test CHP did. 3 cams and 4 intakes. unfortunately in this article, they didn't post the graphs. just peak numbers. which is only one part of the picture. this will help your statements more than it will me. to a point. if we could see the whole picture, i'm positive it would paint a way different picture than what the peak numbers are doing. i would venture to say the graphs would look almost the same as the intake test graphs. just with higher numbers in the upper rpms. when adding a cam to the mix, do aftermarket intakes raise the numbers? yes. do they increase the rpm range? no. remember these are all peak numbers only. but, what it does show is when changing to a higher duration cam, the powerband goes up. seeing as how this thread is in the truck section, unless this is a drag truck, i don't think anyone here with a truck wants higher rpm capability. they want existing rpm capability increased. the higher the rpm you run a motor, the more wear, tear, and stress you put on it. the lower the fuel economy gets.
look closely at this. even comp cams uses a large spread in their first cam. and in the other two cams, again the truck intake outdoes the LS1 intake on my car!!! in both hp and tq!!!! the truck intake is just not a restriction. unless you want to spend $900 for the LSx intake that only beats the truck intake AFTER 5000 rpms. i just can't see spending that much money for it. if anything, get a LS6 intake if you really want to change the intake. but look at the first graphs i posted. the LS6 just keeps up with the truck manifold.
and yes i see all the other intakes made way more power than the truck one in the small cam test. i really wish they would've posted the graphs.
