Comp 212/218 or 216/220?
Old Aug 6, 2005 | 06:41 PM
one03sierra's Avatar
Formerly one92rs
Talking
that 216-220 is also a cam that is being used by a couple a people that are f/i as well.
Old Dec 11, 2009 | 02:47 PM
Z'06's Avatar
Reviving this old thread, because I am trying to decide between these exact two cams (212/218 low-lift v. 216/220). I see a lot of people recommending the 212/218 and the TR220 for a 5.3, so it seems like the 216/220 is a great compromise between the two, and it makes its power from 1300 RPM (just barely more than the 1200 RPM at which the 212/218 low-lift begins making power).
With my Tahoe being only 2WD, will I not lose as much low-end going with the 216/220 as would a 4X4?
I am trying to keep this daily driver emissions-friendly and with relatively quiet valvetrain noise (a low-lift cam that uses LS6 springs). My performance mods are in my sig - all the usual bolt-ons.
Stock stall for now, although I will likely upgrade to a Circle D 2600-3000 (tow-capable) stall at some point. 3.23 gears for now, but going to upgrade to 4.10 or 4.30 with Truetrac at some point when I add 33s. I will also be getting a Blackbear or Wheatley tune after my cam is installed. I have no plans to go with FI - just a fast normally-aspirated truck.
Thanks for any ideas!
Old Dec 11, 2009 | 03:22 PM
SILVERBIRCH's Avatar
I love the way my truck feels with the 212/218 low lift and the Circle D TB reworked stall its so much fun to drive around it also lopes very nice with the borla xr-1 catless very DD freindly I will try and see if I can get some videos soon so you can get a better idea of what I mean yesterday me and Wheatley were out retuning my truck and its feels great thanks for the great tune Charlie.
Old Dec 11, 2009 | 06:11 PM
robt342003's Avatar
anxious to see vids...
Old Dec 11, 2009 | 09:48 PM
SweetS10V8's Avatar
Originally Posted by RedChevy4x4
Anyone want to recommend a better cam for nitrous use. Also, I have 4.10 gears if that matters.
Unless your spraying 90% of the time or more, which you wont be, you dont need a "nitrous" cam....
The 216/220 is a great cam...
Old Dec 11, 2009 | 10:02 PM
budhayes3's Avatar
PT's Slowest Truck
LOL, you just answered a question that someone asked four years ago
Old Dec 11, 2009 | 10:50 PM
LsxCody's Avatar
damn old thread, i used to run a 216/220 cam. ran damn good
Old Dec 11, 2009 | 10:59 PM
Z'06's Avatar
What was your set-up when you were running it? 5.3L? Stall? Gears? Tire height? Tune?
I'm curious about the low-end loss, if any, since the 216/220 seems to start making power 100 RPMs above where the tried and true 212/218 low-lift starts making power, but still a few hundred less than where the TR220 starts making power.
Thanks!
Old Dec 11, 2009 | 11:07 PM
budhayes3's Avatar
PT's Slowest Truck
Joshua (visciousknid) is running the 216/220, and I think that 00ChevyScott used to run it also. I was considering that cam for my LQ9 actually, but I ended up going with the Vinci trucker (216/224 .551 115)
Old Dec 11, 2009 | 11:13 PM
GMCtrk's Avatar
Im pretty sure Scott said the 228/228 has just as good of low end as the 216/220. What you guys aren't taking into account is the fact that the 216/220 has lazy lobes compared to some other cams. The de facto 5.3 cam...the most proven 5.3 cam is the tr220. I think you'd be hardpressed to outdo it throughout the rpm range
