Colorado 3.5 to 5.3 swap
Old Mar 5, 2016 | 02:11 PM
2shawnz's Avatar
Registered User
Cool Colorado engine swap
Before anyone tears me apart. Yes I have read threads on swaping an ls into a colorado. However, none that I have read are detailed to give someone what they need to do it, and some are just plain scetchy. I am looking for a straight up answer on what is needed to swap out the 3.5 for an Ls, most likely from a truck or SUV. I have an 05 Colorado Ls ext cab Z71 4x4 3.5 automatic. I know wiring harness and motor moutns are required. And then? Why get out of the 3.5? It has 260,000 miles on it and its tired.
Old Mar 6, 2016 | 11:52 AM
2WDinSnow's Avatar
Banned
First of all you should go check out 355nation lots of info there.
And for the swap
you need a wiring harness there's a guy in Canada who makes them specific for the colorados for a lot cheaper (and better) than CPW
You need a engine:24x crank will make it a little more involved of a install 58x will be easier wiring wise but you'd have to swap your ecm not that bad of a job
Motor mounts: CPW has the best ones just buy there's
Headers: if your on a budget then stock truck manifolds will work otherwise Doug thorley tri y headers
If your not in a rush you can get this done for $2000 or less making the right deals and doing the install yourself
Old Mar 6, 2016 | 09:32 PM
2shawnz's Avatar
Registered User
Do you have any info on the guy in Canada? 24x crank/58x?
Old Mar 6, 2016 | 10:10 PM
2WDinSnow's Avatar
Banned
He's on 355nation:04colyzq8 (Jamie)
Oh and if you happen to order mounts over the phone don't mention Jamie they hate him lol
Basically gen 3 24x crank reluctor or gen 4 58x crank reluctor
This is his thread
http://www.355nation.net/forum/engine-swaps/38673-making-room-v8-engine-4-banger-coming-out-finished-added-videos.html#/forumsite/20855/topics/38673?page=1
Old Mar 7, 2016 | 01:32 AM
lr4 colorado v8's Avatar
Sent the OP a PM, I go by 04colyZQ8 on the nation. Thanks everyone -Jamie
Old Feb 13, 2022 | 01:24 AM
Rodneypena's Avatar
Registered User
Default Wiring harness
How can I reach the Canadian person with the wiring harness?
Chaney3000
Feb 4, 2016 07:00 PM
Antsilver
48
Feb 3, 2016 03:16 PM
pewter00
Feb 2, 2016 07:08 PM
ATSOWNZ
Jan 22, 2016 09:27 PM
