Cold Engine Studder
Just recently when I start my truck when it's cold (starts up fine and idles fine) and put it in drive and give it gas it starts to studder like it wants to die. Does anyone know what can cause this? Once it starts going and also when it warms up it is fine. It just does this on the initial movement. Does the engine run off a different air/fuel table when it's cold and maybe the computer has a bug somewhere? It has a new fuel filter and good plugs and wires.
For cold starts, the engine runs in open loop until the coolant temperature rises above a certain point (something like 140*F). In open loop, cold engine, cold intake air - the PCM adds extra fuel when you put any load on the engine. Try letting it warm up a little longer before you begin to drive...
Mine does it too, Kyle. I always let her warm up a little. I also noticed one day when it was below zero, that it sounded like it missed a few times right when it started. I don't think the injectors liked the cold or something. Your cold stumble is pretty common though. There may be a PCM update, but don't have them do it since you have programming in yours.
superchomper2003
Aug 26, 2015 09:39 AM
therock
Jul 25, 2015 09:23 AM
Mossyoakglock
Jul 17, 2015 08:30 AM
Suburban2500
Jul 14, 2015 02:10 AM
