Cold air intake and heat soak issues
Old Sep 28, 2009 | 09:39 PM
  #21
budhayes3's Avatar
PT's Slowest Truck
I have the Volant with the ram air tube and I'm very happy with it...it was a bit pricey but it's of good quality and a nice looking CAI. I'm currently running my IAT sensor in the stock location in the MAF, but may eventually relocate it to the EGR block off in the intake.
Old Sep 28, 2009 | 09:41 PM
  #22
tallbluslpr's Avatar
Iat temps make a huge diff. if you have some tuning software such as hptuners you can see that many chevrolet trucks start pulling significant amounts of timing at about 95-100 degrees the timing amount pulled gets higher and higher with intake temps. In FL we see temps in the high 90s all the time
Old Sep 28, 2009 | 09:46 PM
  #23
grey matter 04's Avatar
13 Second Truck Club
yep it pulled 12 degrees i wanna say
budhayes3 have you ever watched your IATs with that setup,what are they?
Dont mind payin if it fixes my issue
Old Sep 28, 2009 | 09:52 PM
  #24
budhayes3's Avatar
PT's Slowest Truck
Unfortunately I don't have tuning software, and my scan tool doesn't display IAT's IIRC (haven't used it in a while so I can't remember lol). Sorry I don't have any help for you there
Old Sep 28, 2009 | 10:07 PM
  #25
well damn
Old Sep 28, 2009 | 11:20 PM
  #26
skolman91's Avatar
I got a cheap ebay cai, today i was watchin it in a fast food line since it was kinda cool today, 65* out and it got up to 95* while sitting and comes back down when u get moving obviously. Mine even touches the coolant hose a little so the tube gets a little warm, but thats after the maf. From what ive read the air moves thru so fast the actual air has no time to heat up, but your maf sure will. I would relocate the iat and call it a day unless u want to build or buy an absolute enclosed filter setup with iat inside i dont see it changin..
Old Sep 28, 2009 | 11:29 PM
  #27
Wheatley's Avatar
Truck Sponsor
Originally Posted by broke1
My opinion is that high IAT's do not cause any problems.Just a # that people seem to get hung up on when in reality ,99.9% of the time the #'s being high doesnt mean crap....
Maybe not the best for extracting all out HP but ill bet you dont lose 1-2 hp.
Not really!!
Hotter intake temps increases the burn rate,when the burn rate increases spark must be pulled.Unless you just zero out the IAT correction table like some do.Not good!!!!!
Old Sep 28, 2009 | 11:34 PM
  #28
gonna make some changes,see what the out come is.
Maybe relocate the IAT sensor if i can get temp to drop
Wanted some input from others for ideas on the issue.
Old Sep 28, 2009 | 11:40 PM
  #29
Originally Posted by Wheatley
No sir that is not correct
Hotter intake temps increases the burn rate,when the burn rate increases spark must be pulled.Unless you just zero out the IAT correction table like alot of people do.Not good!!!!!
no way i would zero out that table,then i would be buyin a motor
I have noticed when it gets real hot take off more than half throttle you can hear some spark knock then pulls timing and no knock
Old Sep 28, 2009 | 11:51 PM
  #30
Wheatley's Avatar
Truck Sponsor
Thats good,I personally would not.LOL
I would work on that though
Sounds like you got the hang of it pretty good!!
