Cluster with speedo above 120 mph
Old Oct 1, 2004 | 09:47 AM
Default Cluster with speedo above 120 mph
Anyone know of a plug and play gauge cluster available for a Silverado that has a speedometer that goes above 120 mph?
*2002 Black RCSB 4.8L, Procharger P1SC@8lbs. w/3-core, BBK 80mm TB, ASM Headers, 2.5" straight pipes w/2 40 series flows, Westers tune, e-fans, built 4L60E w/transgo, Yank tt converter, Eaton, 4.10 gears, $12K in appearance/stereo junk*
Thank God it's Friday
Old Oct 1, 2004 | 11:40 AM
quicksilverado's Avatar
Would be nice. It suck when you don't know how fast you're going.
Old Oct 1, 2004 | 04:43 PM
i guess nobody knows. i wonder if you could modify a camaro cluster. sure it wouldnt be plug and play but it might not be that hard....maybe switch out some of the pieces. just a thought.
Old Oct 1, 2004 | 05:40 PM
TieRod's Avatar
I know a guy with Camaro that has 200MPH speedo he said that it was gage face and Granatelli Motorsports did the install and recalibration.
Old Oct 2, 2004 | 01:09 AM
gametech's Avatar
I was wondering about just recalibrating the speedo to read mph on the kph scale. However, I don't know if there is any way to change the odometer to read correctly.
Old Oct 2, 2004 | 01:51 AM
xXxSilveradoxXx's Avatar
The HyperTech programer will change the readings on the speedometer and it changes the odometer too. I'm not sure how much you can change it though.... I'll have to look.
RustyD
May 23, 2016 07:04 PM
bearden86
26
Nov 15, 2015 03:58 PM
Velocity1
Oct 2, 2015 08:01 AM
jtphelps289
Sep 30, 2015 09:26 PM
Jr. SXT
Sep 30, 2015 07:23 PM
