clogged cat maybe?
Old Mar 24, 2009 | 03:44 PM
lo&sloSierra's Avatar
Default clogged cat maybe?
my truck (03 model sierra) threw all three of these codes at the same time today P0131 P0137 P0151, or other words 02sensor low voltage circuit on Bank 1 sensor 1 and sensor2 and Bank 2 sensor1..........what could have caused this?
Old Mar 24, 2009 | 09:31 PM
budhayes3's Avatar
PT's Slowest Truck
A clogged cat will hold the engine back, from what I've seen on the GM's usually the engine won't rev past 4000 rpm, and will misfire. You'll feel a power loss when trying to accelerate. I'm not aware of a clogged cat being associated with those codes. Low voltage on both banks means that the O2 sensors on both sides are reading too much oxygen. I'd be checking for a vacuum leak or air intake leak allowing unmetered air in.
Old Mar 25, 2009 | 06:49 AM
...well after thinking about it, it all happened in extreme acceleration,so im thinking that not enough fuel was getting there and that tripped the codes, but still it doesnt really make sense because my truck is pretty much all stock
Old Mar 25, 2009 | 11:14 AM
budhayes3's Avatar
PT's Slowest Truck
Maybe the fuel pump is on it's way out or the fuel filter or sock at the end of the fuel pump is paritially clogged?
Old Mar 25, 2009 | 11:17 AM
GMCtrk's Avatar
when was the last time you changed the fuel filter?
madmann26
Apr 29, 2020 09:17 AM
FlowmasterMufflers
Nov 24, 2015 01:00 PM
BlownHD
Oct 3, 2015 12:24 PM
Wolftrk99
Oct 2, 2015 08:17 AM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
