Clearing ses codes?
Old Jun 28, 2005 | 10:12 AM
white1's Avatar
Default Clearing ses codes?
I had a small exhaust leak and was planning on pulling my cats yesterday. I unplugged my O2 sensors, and forgot to plug them back in. The ses light came on, and I remembered. I plugged them back in when I got hame, but the light didn't clear. So I disconnected the batt. for a few minuites, and it still didn't clear. WTF? Is there some special way to clear the codes? I thought once the problem was fixed, they would clear.
Old Jun 28, 2005 | 10:15 AM
TurboBerserker's Avatar
I AM A MOTHERF*CKER
As far as I know, there is no way to clear SES codes on the trucks with out a scanner
Autozone can clear it, or anyone with HPT, EFI, TechII etc. Or an Interceptor Scan gauge.
Old Jun 28, 2005 | 10:16 AM
01Blackerado's Avatar
Its 40-50 ignition cycles or clear it manually with autotap or hptuners or tech II scanners
Old Jun 28, 2005 | 10:40 AM
Black_Silverado_5.3's Avatar
My cousin had the same problem with the SES light. We took his car over to the local auto zone, but they didn't want to clear them...the guy said it was against the law ...We replaced the part that was needed and the SES went away. As far as your situation, the only thing to do might be to take it to the dealership or go to someone with an HP-tuner or scanner to remove it...
Old Jun 28, 2005 | 11:34 AM
BeefTip's Avatar
From: Somewhere between Auburn, AL and Columbus, GA
I would give autozone a try just to see if they will do it or find someone with a tuner, that is close to you. Most handhelds will do the job
Old Jun 28, 2005 | 11:52 AM
PappyDan's Avatar
Tribe Shaman
something similar happened to me but it was with my maf sensor.
after doing some work to the truck I forgot to plug in the maf, the light came on, turned off the truck pop the hood and plugged it back in but the check engine light stayed on.
took the truck to my friends shop asked him if he knew how to turn the light off.
he jumped in, turned on the key but did not start the motor, pumped the gas peddle 5 times in a steady rate, turned off the key switch, then started the truck and the light was gone.
Old Jun 28, 2005 | 03:11 PM
Thats supposed to be the clear oil light method hell if it works then try it
Old Jun 28, 2005 | 03:45 PM
I did the unplug the battery method, except for a couple hours or so. Light went off.
I too also tried it for a brief period, 10 mins or so, and it didn't go away. After that I unplugged it again and just left it unplugged for a while and came back later on that night and it was gone.
Old Jun 28, 2005 | 07:14 PM
white1's Avatar
Thanks for the help. I made a stop on the way home, and to get it cleared, and it went off itself. now I unplugged the EGR and I'll see if it comes back on.
Old Jun 28, 2005 | 07:20 PM
ReedyCreekRacin's Avatar
if it isnt a persistant problem, sometimes 3 or 4 driving cycles will turn it off. crank it up, drive around the block, turn the truck off for a minute or 2. do this a few times and it will usually turn the light off. CHIP
