Chevy silverado idles and turns off in cold weather
Old Feb 8, 2011 | 11:36 AM
SILVY303's Avatar
pics of said truck
Old Feb 8, 2011 | 12:14 PM
06Sierra2's Avatar
just buy a fast intake and you will have another reason to change the gaskets lol. this is what i plan on doing lol
Old Feb 8, 2011 | 04:56 PM
bluelq4's Avatar
a blinking CEL is never a good thing to start, first place to start is this,
*IAC (idle air control)
*EGR valve
both can cause this issue
Old Feb 8, 2011 | 05:32 PM
viciousknid's Avatar
Where's the Beef?
The first thing to do is spray carb or brake cleaner at the intake on the sides and see if smoke comes out of the exhaust. that will indicate a leak or not.
Old Feb 9, 2011 | 11:46 AM
bluelq4's Avatar
A GM way is to use propane (like a hand held torch, not lit of course) and go all around the intake with the truck idleing. if the rpm increase's you've found the leak....
Old Feb 11, 2011 | 04:42 PM
cnukpup's Avatar
Originally Posted by 02'Z71ONDUBZ'
It's not your throttle body. Those trucks have defective intake gaskets in many cases, if their the factory orange ones. The gasket material contracts in extreme cold temps, causing a vacuum leak. Once the engine warms up to operating temperature, in most cases, the heat will cause the gasket material to expand, in turn sealing off the intake leak. The service engine light is coming on because you have un-metered air entering your intake track causing multiple misfires. If your truck sounds like it has a huge cam in it at idle but runs like normal once the truck warms all the way up, and only does it on frigid mornings, you need to replace your intake gaskets. GM put out a service bulletin on this a few years ago.
that happen to my 01 yukon and it was the intake gasket!
GMCSIERRA5.3
Aug 7, 2015 01:50 AM
therock
Jul 25, 2015 09:23 AM
Ketis
Jul 23, 2015 12:37 PM
Mossyoakglock
Jul 17, 2015 08:30 AM
Suburban2500
Jul 14, 2015 02:10 AM
