Chevy silverado idles and turns off in cold weather
Old Feb 3, 2011 | 10:02 PM
SILVY303's Avatar
Default Chevy silverado idles and turns off in cold weather
i have a stock 03 silverado with the 5.3 v8...every morning when it gets cold i start it up, and it idles to the point where it wants to die...as a matter of fact this morning it was around 10 degrees out...after around 5 minutes of being on, it died....another issue is that the CEL turns on as well on when its cold...some times it blinks others it will just stay on...by the way the truck runs perfectly...this is my only issue....any help would be great
Old Feb 3, 2011 | 11:53 PM
grey matter 04's Avatar
13 Second Truck Club
try cleaning the carbon build up off the inside the throttlebody
bet that solves your problem!
Old Feb 4, 2011 | 12:36 AM
Atomic's Avatar
I have a gauge for that
A blinking CEL usually means its detecting a lot of engine misfires...
Old Feb 5, 2011 | 02:58 PM
02'Z71ONDUBZ''s Avatar
It's not your throttle body. Those trucks have defective intake gaskets in many cases, if their the factory orange ones. The gasket material contracts in extreme cold temps, causing a vacuum leak. Once the engine warms up to operating temperature, in most cases, the heat will cause the gasket material to expand, in turn sealing off the intake leak. The service engine light is coming on because you have un-metered air entering your intake track causing multiple misfires. If your truck sounds like it has a huge cam in it at idle but runs like normal once the truck warms all the way up, and only does it on frigid mornings, you need to replace your intake gaskets. GM put out a service bulletin on this a few years ago.
By the way I speak from experience, this happened to my truck.
Old Feb 7, 2011 | 07:08 PM
and mine x 2 to change your intake gasket
Old Feb 7, 2011 | 07:11 PM
viciousknid's Avatar
Where's the Beef?
intake gasket. Just put another engine in my z71 and didn't change the gaskets on the intake. Once we fired it up it would idle rough and even rev up to 2500 and come back down and try to die. O'reilly's had gaskets for about $40. Take you maybe an hour to change em
Old Feb 8, 2011 | 11:15 AM
SILVY303's Avatar
thnks for the help guys....ill replace my intake gasket today...see how it works cuz its gona be really cold tomorow
Old Feb 8, 2011 | 11:25 AM
BlackGMC's Avatar
Resident Retard
How about telling us what the code is before you start buying parts
Old Feb 8, 2011 | 11:33 AM
SILVY303's Avatar
po174 and po173
already changed all the 02 sensors
and cleaned throttle body.....
edit:will not change intake gasket myslef....way to hard for me lol
