Check out the exhaust valves on my PRC heads...
Old Dec 21, 2010 | 11:58 PM
BlackGMC's Avatar
Resident Retard
Default Check out the exhaust valves on my PRC heads...
Well i got my LQ9 swapped in this weekend, and i was thinking about putting my PRC heads on it later, but when i had the 4.8 on the stand i looked at the exhaust valves, they are white and crusty... All of them look like that and all the spark plugs were white too. Tell me this is not normal...
Old Dec 22, 2010 | 01:22 AM
TX Tahoe Z71's Avatar
My guess is running lean as hell or fuel additives. Maybe E85? Not sure what color it leaves behind.
Old Dec 22, 2010 | 01:43 AM
AKlowriderZ71's Avatar
11 Second Hall Moniter
It's not normal. Send them to me for analysis.
Old Dec 22, 2010 | 06:43 AM
silver-mod-o's Avatar
Hunt&Fisherator
I've seen stock heads come off stock engines look like that Corey. I know you're on top of your tuning. I say disassemble them, inspect everything, re-lap all the valves and clean them up and put them on the 6L without thinking twice.
Old Dec 22, 2010 | 07:23 AM
krambo's Avatar
My Radix'd 6.0L looked almost like that when I pulled it. I took some acetone and tried to wipe the valve stems off however the color didn't change. I did not run lean at WOT however did run a 50/50 methanol mix with pump 93 (usually a 10% ethanol blend) and the rare occasion of C16 for the track.
I hope an engine builder chimes in here as I am all ears on this one.
Old Dec 22, 2010 | 07:44 AM
Bigredmariner's Avatar
Looks pretty much like what I saw on my 5.3, never worried much about it and nothing has melted down yet. Never been lean either and about all I can get is 93 octane with a 10% methanol.
Old Dec 22, 2010 | 07:49 AM
RibeiroBJJ's Avatar
Praise The Lowered
X2 on my Radix'd SSS looking the same..but I ran a mix of 91/110 vp ...Interested on reason as well....
Old Dec 22, 2010 | 08:51 AM
TXsilverado's Avatar
lap them and throw em' on. you could have saved yourself alot of grief by doing the head swap on the engine stand.
Old Dec 22, 2010 | 09:00 AM
Bumpers's Avatar
Yea why didn't you put em on while the engine was out ? Its not anywhere near as fun doin it in the truck
Old Dec 22, 2010 | 09:55 AM
BlackGMC's Avatar
Resident Retard
Cool, ya i never ran it lean intentionally, however i did have a 02 sensor die on me and I ran it for a couple hundred miles... But I would have expected the damage to be only on 1 side not both. I will take them apart in a little while.
Originally Posted by Bigredmariner
Looks pretty much liked what I saw on my 5.3, never worried much about it and nothing has melted down yet. Never been lean either and about all I can get is 93 octane with a 10% methanol.
Well that is good to hear.
Well i wanted to take them apart and have them checked out prior to putting them on my new motor. The old motor used some oil and it started using oil when i put the heads on...
