Check this out, 15hp 17tq from just plug wires......BS I think.....
Old Apr 21, 2007 | 12:32 PM
Default Check this out, 15hp 17tq from just plug wires......BS I think.....
http://www.hanoverinn.com/mpg/gas-mileage-enhancer.html
I was just searching around and found this. I thought the vararam and tornado were pretty full of ****, but this has to take the cake!!! Also to the left there is a guy from Jax, FL saying he gained tons of power and 3.5mpg on his Cobra with these wires. I used to buy my N2O at that guys shop and always knew he was full of it.
Old Apr 21, 2007 | 01:06 PM
Ferocity02's Avatar
Spark is spark... aftermarket wires are only for reliability IMO.
Old Apr 21, 2007 | 01:35 PM
You do gain a little more spark and a couple hp at best with less resistive wire, but no more than 4-5hp on older motors with 3 ft wires. Our short wires maybe 1-2hp.
Old Apr 21, 2007 | 02:05 PM
PappyDan's Avatar
Tribe Shaman
well if that is the case, why not build a bracket to move the coils
closer to the plugs, where we can use a 4" wire instead of an 8" wire.
make it even better, build a bracket with a heat shelid to connect the coil
almost directly to the plug with some kind of 2" connection.
or has this already been done with no results of any gain at all.
Old Apr 21, 2007 | 02:57 PM
Alot of the high power 4 bangers have no plug wires, the coil sits directly on the plug. You wouldnt see any worthwile gain from moving the coils closer.
I did gain nearly 3mpg on my 2001 Grand Am 2.4L when I took the stock plugs out and put in the platnimum+4's. It also idled smoother and felt better responce. It had about 45k on the stock plugs when they came out.
Old Apr 22, 2007 | 01:54 AM
PappyDan's Avatar
Tribe Shaman
are you sure you just did not need a tune up. lol
Old Apr 22, 2007 | 02:24 AM
00BlueTA's Avatar
12 Second Club
Thats what I am thinking
Old Apr 22, 2007 | 08:09 AM
FASTBLKSRT's Avatar
Old Apr 22, 2007 | 08:55 AM
Mr. Sandog's Avatar
And as far as reliability, stock wires are great. Aftermarket wires have many more problems - just do some digging and you will easily find some horror stories from all of the manufacturers.
Old Apr 22, 2007 | 09:06 AM
I guess I could have. All the miles were easy highway, but the plugs could have just needed changed. I am not a believer in the 100k miles plugs. I like to change mine every year or every 40k which ever comes first.
Your right about stock wires being reliable, I have bought 2 sets of performance wires in my life and had trouble with both sets. I've never had problems with stockers.
