Check my fuel pump wiring
Old Jul 19, 2007 | 11:06 PM
1SlowHoe's Avatar
Destroyer of Transmissions
Originally Posted by thunder550
Meaning that when he figures it out he will be bleeding from the ears and possibly a crushed rib cage?
One can dream.....
Old Jul 19, 2007 | 11:07 PM
thunder550's Avatar
High on diesel fumes
Originally Posted by 1SlowHoe
One can dream.....
Old Jul 19, 2007 | 11:10 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
One can dream.....
You're not going fishing with us
Old Jul 20, 2007 | 12:05 AM
Richard@WCCH's Avatar
FormerVendor
This resembles a funeral derge..........
Richard
Old Jul 20, 2007 | 02:12 AM
Grumpy5.3's Avatar
hey cody,
did you happen to check the ECMB fuse??? I have seen that fuse blow and the truck will just shut off if running, and not start if not
Old Jul 20, 2007 | 07:12 AM
1slow01Z71's Avatar
ECMB fuse?
Old Jul 20, 2007 | 12:45 PM
ramdaspadhye's Avatar
He might be talking about the EBCM fuse... Electronic Braking Control Module (ABS).
Mine blew, pump continued to run, had to pull the fuse to get the pump to shut off. Truck kept running. Having the electric parts replaced now,t hough. 150 bucks sure beats 900 for a new unit.
Old Jul 20, 2007 | 12:50 PM
1slow01Z71's Avatar
So a fuse for the ABS could keep my FP from working?
Old Jul 20, 2007 | 01:09 PM
Grumpy5.3's Avatar
no it is an ECMB fuse, its in the underhood fuse block
Old Jul 20, 2007 | 02:19 PM
Nick™'s Avatar
With my finger on the FP relay in the fuse block under the hood, my buddy hit the key and you could feel it click on for a couple of seconds then turn off. Just like it should, when you turn the key on it will pressurize the system then cut off till you start it.
well if it's pressurizing then it's getting power and working. Have you checked your fuel pressure at the rail? if no pressure maybe the hose that connects the fuel pump to the lid for the bucket (where the fuel lines are) failed? did you reuse that plastic piece from the factory or did you just use rubber FUEL INJECTED fuel line (must be for a fuel injected vehicle or it'll blow).
Either way if it's coming on and priming it's not an electronic problem, it's either the fuel line in the bucket or maybe even a bad fuel pressure regulator.
on edit:
I see that you reused that plastic hose, I didn't feel comfortable with fitting it to the walbro pump so we used high pressure fuel line (any auto part store) and the supplied clamps on Matt's truck.
