Cheapest lq4 long block
Old Jan 26, 2018 | 05:15 PM
Patrick05's Avatar
Default Cheapest lq4 long block
im looking into replacing the lm7 in my 05 2wd with a lq4. So far the cheapest I can find is a reman motor from rockauto. Also, has anyone used a finish line trans? I plan on swapping my trans out for one of theirs hopefully at the same time.
Old Jan 26, 2018 | 06:25 PM
FFDP's Avatar
A junkyard pull out or a craigslist 6.0 would be cheaper than a reman.
In fact you could likely buy 2 or 3 used engines for the price of a reman unit that isn't even fully assembled.
Old Jan 26, 2018 | 06:50 PM
Patrick05's Avatar
I’m wanting to stay with a new motor if possible.
Old Jan 27, 2018 | 06:31 PM
brandon6.0's Avatar
Where u located? I see them all the time here in the south
Old Jan 27, 2018 | 09:01 PM
2002_Z28_Six_Speed's Avatar
your cheapest option is probably have your original motor refreshed with factory replacement parts by a local rebuilder with a good reputation.
Old Jan 27, 2018 | 10:31 PM
Tig's Avatar
Tig
What's your budget?
I had an FLT trans, in fact, it's still running great with the new owner. It's almost 10 years running strong. Matched with a Yank 3200 billet stall. Though it doesn't get daily use much, it still runs.
Old Jan 29, 2018 | 05:18 PM
Patrick05's Avatar
im wanting to go with a 6.0 over my 5.3 for more power to haul with. And I don’t really have a budget, but not really wanting to spend $5000 on a crate motor. Rock auto has them Renan for $2000.
Old Jan 30, 2018 | 07:56 AM
Drspencer's Avatar
5 Year Member
You need a new or remanned 6.0 for less than $2,000? Used down here they're rarely below $1,200. You could go to LKQ and pull one for $350 plus an extended warranty of $83. If you have the engine out and are using it for towing, you should want to stick a cam in it and it's gonna need a tune anyway.
53bowtie
Dec 28, 2012 10:10 AM
mconway68w
Jun 26, 2011 06:47 AM
00Silv4.8
May 29, 2010 08:30 PM
1ImperialSS
Dec 24, 2006 10:47 PM
