Change knock sensors while I'm in the area?
Old Aug 15, 2009 | 09:32 PM
  #21
budhayes3's Avatar
PT's Slowest Truck
Are you using the 00 OS or an 01+ OS? I know that the 99 PCM's were known for false KR problems, the 00 may be also...I'd assume that Justin would update that but it would still be good to know for sure
Old Aug 15, 2009 | 09:33 PM
  #22
GMCtrk's Avatar
02 os
  #23
BlackGMC's Avatar
Resident Retard
is this on the stock tune? What all mods are done to your truck?
Old Aug 15, 2009 | 09:34 PM
  #24
GMCtrk's Avatar
stock 2002 lq4 tune i pulled of holden crazy. only mod to the 6.0 is the heads with 10.6ish:1 compression. I can't do any more mods until I figure out why this is doing this!
Old Aug 15, 2009 | 09:38 PM
  #25
BlackGMC's Avatar
Resident Retard
This is just my opinion... it appears you don't have a leak, your problem is that your running around untuned... The reason why your getting KR is because your lean as **** at WOT... If you still had a leak the your trims would keep growing and growing until that maxed out. Also are you running a MAF? if so you need to add GM.MAF to your PID list.
post up your tune and i will make a few changes real quick
Old Aug 15, 2009 | 09:39 PM
  #26
sonoma43's Avatar
dont you have EFI?
could it be false knock at all? stock tune with higher compression and diff. heads, the airflow and fueling will be alot different...
Old Aug 15, 2009 | 09:41 PM
  #27
BlackGMC's Avatar
Resident Retard
No that is real knock
add GM.MAFFREQ not GM.MAF like i posted earlier...
  #28
GMCtrk's Avatar
I am running a MAF, but you say I dont have a leak...that does not explain the whistling sound I get at high load in 4th with the converter locked. It sounds like high velocity air leaking in somewhere.
File Type: tun
Old Aug 15, 2009 | 09:47 PM
  #29
BlackGMC's Avatar
Resident Retard
I have no idea about the noise, maybe it is not engine related and it is some bad weatherstriping...
either way, try this tune and see if your KR goes away, make sure you add that PID i said, load it up, go log it and post it up...
File Type: tun
Old Aug 15, 2009 | 09:49 PM
  #30
GMCtrk's Avatar
Could you please tell me what all changes you made? I'd like to look at that briefly.
Also, I'm almost positive the whistling noise is related to the engine because it always happens when I press the gas down. It all seemed to start last year when I put a ported TB on....now I'm running the stock one agaim.
