Change knock sensors while I'm in the area?
Old Aug 15, 2009 | 06:27 PM
00ChevyScott's Avatar
Wearin' da big hat
Originally Posted by GMCtrk
If I had extra money I wouldn't be dealing with this old garbage
In that case I'd suggest just replacing the PCV valve and it should help cut down on the oil sucked into the intake. It looks like that could've contributed to your gaskets flattening so much.
Old Aug 15, 2009 | 07:55 PM
GMCtrk's Avatar
Ok just fired it back up, need to clean up before I take it for a drive. Torquing to 44 in lbs and the 89 in lbs in sequence is a bitch...specially trying to get that big *** torque wrench in there.
Anyways, I noticed that the thing sticking out up top of my manifold in the front, the screw doesn't go all the way down??? It looks like there is supposed to be some washers or something in between the screw and the plastic surface?? This could definitely where the leak is coming from. Seems like a stupid design from GM.
Old Aug 15, 2009 | 08:02 PM
BlackGMC's Avatar
Resident Retard
hard to tell from your pic, but i believe that is the evap soleniod.... Hopefully this fixes your problems so you can finally start tuning... BTW do you have wideband???
Old Aug 15, 2009 | 08:05 PM
GMCtrk's Avatar
No wideband. I'll have Justin write me a tune and then see what my o2 sensors are reading at WOT. I'll pretty much know right away if the problem is fixed or not.
I'm planning on getting another set of headers w/wideband bung, but the **** *** header sound bugs the hell out of me. I know I'm a ***** and all, but I hate the inside of my truck sounding like a popcorn machine. I've been looking at ARH 1 7/8 headers and maybe they are made of higher quality materials than the obx, dynatech headers I've used in the past?
Old Aug 15, 2009 | 08:07 PM
BlackGMC's Avatar
Resident Retard
or you could get them coated inside and out... that is how mine were done and the noise is alot less...
Old Aug 15, 2009 | 08:10 PM
dlt76028's Avatar
that thing is always loose since it only has one bolt holding it.
Old Aug 15, 2009 | 08:11 PM
GMCtrk's Avatar
The weird thing is the bolt doesn't even tighten down on the plastic! The bolt is as far down as it will go in the screw hole but it doesnt snug up on the solenoid itself??? Basically you just put the thing on with your hand and it looks like it has an O ring and that's it. It seems very likely it could leak
Old Aug 15, 2009 | 08:14 PM
Wearin' da big hat
I think its just the O ring that keeps it in place. That bolt doesn't really do much haha
Old Aug 15, 2009 | 09:22 PM
budhayes3's Avatar
PT's Slowest Truck
If that's the hose for the EVAP and it was leaking, you'd have an EVAP code, so I doubt that's your problem. Definitely get a catch can, I've tried switching PCV vavles, running the updated fixed orifice PCV valve, and it did nothing for my oil consumption. I tested this with a catch can installed, and both the original spring and plunger PCV and the fixed orifice PCV filled the catch can at the same rate. I empty my catch can every 500 miles or so.
Those intake gaskets look fuked, the gaskets look hardened and flattened, and from that last pic, the gasket looks warped. Hopefully the new gaskets will solve your problem.
Old Aug 15, 2009 | 09:25 PM
GMCtrk's Avatar
Guys, I dont know what to do, I'm so fed up. Same damn noise when I roll into the throttle in 4th, like a high pitched whistling noise. Still ~7 deg of KR at WOT. I'm ready to say screw this thing. LTFTs are between 5-10%. What the hell could still be leaking? I replaced the intake gaskets and the throttle body gasket.
File Type: efi
