Carbed LS for an S-10
Old Nov 15, 2013 | 05:27 AM
custm2500's Avatar
Ph.D. in HUBRIS
Default Carbed LS for an S-10
A friend of mine is building a s-10 that is going to be a boosted 5.3. I am selling him the engine from an 2001 burb. I will post some pictures as he makes progress because right now it is a gutted chassis.
My main question now is what if any of the harness is he going to need for the MSD 6LS? Doese it come with all the wiring for the coils or do you have to use some of the stock wiring. Along with this does he need th stock computer at all?
Old Nov 15, 2013 | 06:46 AM
custm2500's Avatar
Ph.D. in HUBRIS
One other question. He is using a TH350 trans. Does he need the pilot bushing and or anything else to make it work? Will the flywheel from the "01 engine work. Thanks.
Old Nov 15, 2013 | 07:17 AM
Koots's Avatar
Everything I've read says you need a spacer and bushing to properly mount a TH350 converter. I believe the rest bolts up in place AFAIK.
I haven't looked into this in almost 2 years now, so my memory is foggy. I have a fully built TH350 just sitting around, but I have an extra Alto Red Eagle rebuild kit and one rebuildable transmission and wanted to use it with an LS build.
Old Nov 15, 2013 | 08:14 AM
silver-mod-o's Avatar
Hunt&Fisherator
Go do some reading on 'tech, this is a much more common deal over there
Old Nov 15, 2013 | 08:16 AM
AJII's Avatar
You don't need any of the factory harness or factory computer for the MSD box.
You'll need to use the spacer that comes with the 80e as well as a flexplate with holes drilled for a TH350 (neither the 60e or 80e have the same bolt pattern)
Old Nov 15, 2013 | 08:17 AM
AJII's Avatar
Very true. There this is an every day thing all you have to do is search.
Old Nov 15, 2013 | 09:25 AM
TXsilverado's Avatar
keep the map sensor from the efi setup. the MSD box has provisions for it. he will need to get a TPS sensor mounted to the carb somehow.
http://www.summitracing.com/parts/tci-377400/overview/
LSXstef
Jul 19, 2016 02:59 PM
Skip Fix
22
Jul 9, 2016 07:08 PM
dirt track racer 81
Sep 21, 2015 06:44 PM
reddfox
Sep 15, 2015 07:22 PM
