Carb Hat
Old Mar 29, 2009 | 06:19 PM
dirt track racer 81's Avatar
Default Carb Hat
I gotta Vic Jr that should be here in a week or so. I'm going to run 4150/4500 4-barrel throttle plate and trying to figure out what route I'm going to go out running a carb hat to a 4 in pipe or just run an open element filter which i do not want to do. So far heres what Ive found for a carb hat. If i do go with this one it will be the black one. For you guys that have gone this route what have you done? http://cgi.ebay.com/ebaymotors/Carb-...spagenameZWDVW
Old Mar 29, 2009 | 06:29 PM
Im pretty sure this is a one size fits all...
j/k
Old Mar 29, 2009 | 06:46 PM
thunder550's Avatar
High on diesel fumes
superiorairflow dot com
Old Mar 29, 2009 | 06:50 PM
thunder550's Avatar
Have you bought the TB already?
Old Mar 29, 2009 | 06:55 PM
No I havent yet
Old Mar 29, 2009 | 07:18 PM
thunder550's Avatar
If you're interested, I'd sell you my setup above with the throttle body, Lokar throttle cable ends, and carb hat for $560. TB is Edelbrock 3878, 1.75" bores, 1000 cfm and includes the IAC and TPS. I'd send you my throttle and cruise cables as well (since I cut the ends to put the Lokar cable ends on) if you would send me your uncut ones in return.
Old Mar 30, 2009 | 10:40 AM
ZR1 DREAMING's Avatar
<----See avator, that's how I wanted to do my Vic Jr set-up. I wanted to isolate it from the engine heat only drawing air from the cowl hood.
LSXstef
Jul 19, 2016 02:59 PM
Skip Fix
22
Jul 9, 2016 07:08 PM
dirt track racer 81
Sep 21, 2015 06:44 PM
SloSVO
Sep 12, 2015 06:56 PM
