cant leave well enough alone : (
Old Aug 22, 2009 | 10:45 PM
Default cant leave well enough alone : (
so i home ported my throttle body and afterwards i reinstalled it to a messege popping up saying "reduced engine power". did some research and did what it said, got my pcm reflashed to compinsate more air in the 1514 table. still running like crap and throwing a code. what should i do? full tune? also sounds like the thing is missfireing but everything looks good. please help asap TIA
Old Aug 22, 2009 | 11:14 PM
garcia's Avatar
did you overport it?I had mine done last monday and it works awesome.Picked up some low end power on my 2000 silverado singlecab 4.8 with intake,tuning,muffler,and electric fans
Old Aug 22, 2009 | 11:15 PM
garcia's Avatar
Did you port the butterfly area?Where the blade opens and closes,that might be the problem.I haven't retuned mine and it didn't throw any codes
Old Aug 23, 2009 | 08:41 PM
no i didnt get in were the butterfly sits but i got to right in front of it. should i get a full tune or possibly a bigger throttlebody? i just dont want to go back to stock if at all possible. i was thinking though, i took the blade out and i removed the left side piece that bolts in were the gears are and the top gear fell out. my question i guess is the dot on one of the teeth?, does it need to line up with anything? TIA
Old Aug 23, 2009 | 08:51 PM
Wonderer876's Avatar
Make sure you have the butterfly adjusted where it is in there without restrictions and even all the way around, should have marked before removal. Thats what your prob is almost guaranteed. Had the issue til i had it adjusted just right
Old Aug 23, 2009 | 08:56 PM
Spoolin's Avatar
GFYS and STFU
Pics!!!
Old Aug 23, 2009 | 09:25 PM
nightrunner's Avatar
Mr. Obvious
make sure your maf is hooked up good
Old Aug 25, 2009 | 09:41 PM
maf was hooked up good i never removed it. i went to take pics for you guys today and my camaras dead. so i took a look at the throttle blade and realized that the blade wasnt set on there evenly so i loosened it up and repositioned in an even manner. i will reinstall tommorow. does this sound like something that may have been the problem?
Old Aug 25, 2009 | 09:42 PM
it was getting stuck before it closed to were it's preset to sit.
Old Aug 25, 2009 | 09:59 PM
where do you live I got a couple extra throttlebodies, I'm sure I can sell you one.
