Can i use this with the maggie?
Old Jan 17, 2007 | 10:21 PM
NORCAL TBSS's Avatar
Restricted User
Default Can i use this with the maggie?
http://www.holley.com/16034NOS.asp
or is meth better?
Old Jan 17, 2007 | 10:44 PM
thunder550's Avatar
High on diesel fumes
I usually see those used with air/air intercoolers. I don't know how efficient they would be on an air/water i/c. I'd say you'd be better off with meth.
Old Jan 17, 2007 | 11:25 PM
Revolutionary's Avatar
totally ineffective on a water to air setup. Water does not disipate heat nearly as fast as the air to air thermal transfer.. its called thermaldynamics.. I took a whole class that rotted my brain on it a couple years back in school.
Anywho.. you would be best off doing chemical intercooling.. by the time the water gets back to the blower even if you drop it 5 degrees.. after friction loss though the hoses and the actual heat exchanger design your nitrous blast is shot.
My best advice.. if you are going to spray 'er do a wet kit and do give those nitrous nozzles a shot the ones that came out about a year ago they install under the injector.. I bet you could hit that thing with a 50 shot under that nozzle and that whole thing about the 112 heat soak would be a thing of the past.
Old Jan 20, 2007 | 05:17 PM
Restricted User
meth or alky?
rednekferlife101
32
Jan 8, 2016 10:42 PM
old motorhead
Sep 29, 2015 08:22 PM
hackrst
Sep 2, 2015 05:27 PM
06 4.8
Aug 21, 2015 11:33 PM
SSThunder03
Dec 4, 2006 09:10 PM
