Can I safely run a 212/218 high lift with LS6 springs.
Old Oct 5, 2007 | 01:21 PM
KY_BOB's Avatar
Default Can I safely run a 212/218 high lift with LS6 springs.
I have read some posts saying it was OK but I'm putting 10psi of boost on the intake valves. I would like to shift it in the 6200-6400 range.
Cam specs:
Cam Style: Hydraulic roller tappet
Basic Operating RPM Range: 1,500-6,800 RPM
Intake Duration at 050 inch Lift: 212
Exhaust Duration at 050 inch Lift: 218
Duration at 050 inch Lift: 212 int./218 exh.
Advertised Intake Duration: 265
Advertised Exhaust Duration: 271
Advertised Duration: 265 int./271 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.558 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.563 in.
Valve Lift with Factory Rocker Arm Ratio: 0.558 int./0.563 exh. lift
Lobe Separation (degrees): 115
Intake Valve Lash: 0.000 in.
Exhaust Valve Lash: 0.000 in.
Computer Controlled Compatible: No
Grind Number: LS1 XR265HR-15
Old Oct 5, 2007 | 01:23 PM
El_Diablo's Avatar
I wouldn't. dual valvesprings are cheap compaired to bent valves/cracked heads/chewed up cylinder walls. Especially if your are boosting....it'd prob start getting scary at 3000 rpms.
Old Oct 5, 2007 | 01:24 PM
KY_BOB's Avatar
I like the idea of LS6 springs for 2 reasons. 1. They are cheap. & 2 Comp 918's have a bad reputation for being noisy. I'm just not sure that they are strong enough for my application.
Any opinions or experience with similar setup?
Old Oct 5, 2007 | 01:28 PM
El_Diablo's Avatar
it's your engine man. At your mod level..I'm surprised your worried about a spring being too noisy. I run Patriot Gold duals in the Z28. The exhaust note overpowers the sewing machine under the hood. :Edit: Stock Z06 cam lift is .551/.551 I believe. More than that + boost just doesn't seem like a safe bet to me.
Old Oct 5, 2007 | 01:40 PM
KY_BOB's Avatar
Your probably right. The budget is tight right now and I'm trying to make this fit in but I don't want to save $100 and blow an engine.
I know that Lingenfelter sell those springs with their GT2-3 cam which is higher lift than the Comp cam but the ramps may not be as aggressive.
Old Oct 5, 2007 | 01:42 PM
El_Diablo's Avatar
I'm not sure of the lingenfelter but the XRs are pretty brutal. I'm assuming you are going with hardened pushrods as well? Do what I do when funds are running short...sell parts I don't need. Last one was the Air conditioning...lol On the car of course, never the truck.
Old Oct 5, 2007 | 01:57 PM
KY_BOB's Avatar
Yea, pushrods are a given.
Old Oct 5, 2007 | 02:12 PM
KY_BOB's Avatar
...ALSO, any comments on how well that cam will work with my setup are appreciated.
Old Oct 5, 2007 | 07:50 PM
Coban's Avatar
Im going with LS6 springs next time I do a cam swap. I have the 918s in there. Im always afraid they will break. And they are freaking noisy.
For what its Worth, Lingenfelter runs LS6 springs with the GT2-3 which has slightly higher lift than the hilift 212/218.
Old Oct 5, 2007 | 08:15 PM
silveradol33's Avatar
I have a comp 222/224/112lsa and I have the z06 springs, this is on an l33 and I had a similar cam in an lq9 with the same springs. I know alota people who run them and never have any probs. Personally I think all non-stock springs are "noisy"
