Can I cut away the AC bracket bolt hole from the block?
Old Jan 13, 2012 | 03:18 PM
Turboswede's Avatar
Default Can I cut away the AC bracket bolt hole from the block?
I tried to fit my Corvette C5 ls1 Engine bracket on my Chevy lm7 today. I mounted the one on the driver side without any problems, Then I came to the passanger side.
The bolthole for the AC is in itīs way and need to be cut away to make the bracket line up for the boltholes. So I wonder if I can cut it away without any problems? I will not use AC in my car.
Here in the green ring you see the space between the bracket and itīs mounting hole. And in the red is the piece I want to cut away.
Old Jan 14, 2012 | 10:25 PM
livefast1's Avatar
Notch the mount?
Old Jan 14, 2012 | 10:29 PM
Atomic's Avatar
I have a gauge for that
Cut away, IMO. I wouldnt cut more than flat with the ribs on the block, though.
Old Jan 14, 2012 | 11:06 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
I wouldn't hesitate.
Old Jan 15, 2012 | 07:25 AM
silver-mod-o's Avatar
Hunt&Fisherator
Fire up the grinder
zblee
63
Jun 10, 2023 01:25 PM
HectorM52
Aug 18, 2015 12:40 PM
Denali08
Aug 9, 2015 04:34 PM
steves86ta
Jul 28, 2015 10:21 AM
Gadgetized
Jul 22, 2015 11:55 AM
