can air intake noise cause kr and pull timing?
Old May 10, 2005 | 07:43 PM
Default can air intake noise cause kr and pull timing?
just did a homemade cold air about a week ago. ran good for a couple days now its like a dog. any help? its an '00, are the pcms that sensitive to noise?
Old May 11, 2005 | 04:09 PM
ttt.............
Old May 11, 2005 | 08:45 PM
budhayes3's Avatar
PT's Slowest Truck
I don't think that the harmonics caused by the extra air would confuse the knock sensors that way. Is it possible that some junk got on the mass air flow sensor, or something got sucked into the air box restricting flow?
Old May 11, 2005 | 11:16 PM
02sierraz71_5.3's Avatar
if something is loose or banging around that will cause kr most people just have problems in the exhaust side but Im sure its possible I would double check everything
Old May 11, 2005 | 11:23 PM
desTRUCKtive's Avatar
If your intake cam lose or something then it would. I remember mine came loose and crap and was doing all kinds of crazy crap. But if that is ok then most likely it would be the MAF.
Old May 12, 2005 | 12:36 AM
vanillagorilla's Avatar
Try cleaning the MAF first, especially if you put a new filter on. Buy some electronic parts cleaner and clean that baby off. I had to do that, because the wonderful people at K&N like to over-oil the filters.
It's something you should do regularly anyway.
Old May 12, 2005 | 02:41 PM
i think ill try and clean it cuz most of the screen is black color and parts of it are whiteish/silver. im thinking it should be the latter color. thanks for your help guys.
B.love18
Sep 21, 2015 08:31 PM
Ketis
Jul 23, 2015 12:37 PM
Suburban2500
Jul 14, 2015 02:10 AM
08DenaliT
Jul 8, 2015 09:13 PM
supersportsteve
Jul 4, 2015 12:02 PM
