Camshaft selection for 6.0 tow rig.....
Old Dec 2, 2003 | 08:04 PM
Ron@Vengeance's Avatar
LS1Tech Premium Sponsor
Default Camshaft selection for 6.0 tow rig.....
Hey guys, I need some advice on a camshaft for my 04 HD. 6.0 with 4:10s. Ive got a 10,000lb camper Ill be pulling from time to time and I want a cam that has some more torque to it than stock. As I said, this is primarily for towing. I would like to retain as much STOCK drivability as possible. I do have a UPD induction and full exhaust. Any help is appreciated.
Old Dec 2, 2003 | 08:08 PM
BigTex's Avatar
My vote is for a nice Comp XE High lift 212 212 .558 114 cam.
Old Dec 2, 2003 | 11:06 PM
1BADHD's Avatar
After many conversations, phone calls and emails. This is the one I have been STRONGLY directed towards. 212/212, .528"/.528", 112 LSA with +4 degrees of advance
Old Dec 2, 2003 | 11:24 PM
Flyer's Avatar
This one sounds nice .. I would run it on a 115 center though. It would retain a much better idle and keep the power down a little lower. You might be able to get away with not having to get it tuned.
If you want the choppier idle, go with a split duration, something like a 208/212 .524/.534 on a 114. That will give you a small chop in the idle. It might even yield a little better gains.
Old Dec 3, 2003 | 12:01 AM
BigTex's Avatar
My thoughts exactly. I definitely wouldn't do a 112. I'm running a 114 right now in my 6L, and if I had my choice, I'd move to a 115. That being said, I'd still go for the higher lift over the plain XE lobe.
Old Dec 3, 2003 | 03:51 PM
1slow60's Avatar
Whats the biggest lift that you can get away with on these heads safely? Assuming changing the springs. I did a search on this about a week ago and came up empty on the 6.0L heads.
carid
Oct 28, 2015 08:24 AM
chvy=power
Sep 8, 2015 11:06 AM
SWINGRRRR
Sep 3, 2015 07:49 PM
Alvin@PCMofNC
Sep 3, 2015 06:38 AM
