Camshaft question
Old Jan 18, 2018 | 03:56 PM
Silversierra10's Avatar
Registered User
Yeah I'm just swapping cam, but with more airflow I might be better off keeping the 799's... Or not? I might add a tune to it eventually also.
Old Jan 18, 2018 | 04:16 PM
FFDP's Avatar
Keep the 799's, best stock heads out there.
Also there is no "might" add a tune, it's a "must" do a tune. No matter what, if you swap camshaft the engine needs a tune. They do not self learn or self tune for changes made to the airflow model. All airflow and fueling calculations will be incorrect if you swap camshafts so a tune is required.
Old Jan 18, 2018 | 04:27 PM
swathdiver's Avatar
5 Year Member
It's not likely that you'd have LS6 springs from the factory. Most have the 12589774 which has a max lift of .520.
Old Jan 18, 2018 | 04:39 PM
swathdiver's Avatar
5 Year Member
Originally Posted by Drspencer
...Super Chevy did a test with all the popular LS heads and the 706/862 heads made the most power on a 5.3.
Surprising HP Numbers From Our Stock LS Cylinder Head Test
It would be nice if these guys would set up the test engines for the real world, using a streetable camshaft for either a muscle car or one designed for a truck and run the same compression ratio to eliminate as many variables as possible. I enjoy doing such tests and reading about them but this one I think is flawed because of the compression ratio differences.
Old Jan 18, 2018 | 05:07 PM
Drspencer's Avatar
5 Year Member
Yeah I wish they would’ve done the doggon 07 and up intake instead of that Fast unit.
Old Jan 18, 2018 | 05:22 PM
Registered User
Brian tooley did that with a cam called low lift truck cam.
. 500/. 500, 115 lsa, 224/230
they claim HP gain up to 66 HP.
No hardware change required.
Numbers are very similar than the lh9 cam.
Old Jan 18, 2018 | 06:22 PM
Drspencer's Avatar
5 Year Member
I meant a head test but using the truck intake.
Old Jan 18, 2018 | 07:09 PM
Registered User
I hear you now
Old Jan 19, 2018 | 10:22 AM
swathdiver's Avatar
5 Year Member
Isn't that an AFM/VVT camshaft?
Crane developed a Gen III camshaft that made near 50 horsepower over stock with a 200-200 duration, same lift on a 113 LSA.
Old Jan 19, 2018 | 11:50 PM
Registered User
No afm just vvt, 1 bolt can, 4 x gear
