Camshaft for '99 LM7 5.3L
Old Dec 21, 2003 | 11:47 AM
SuthernFlames316's Avatar
Question Camshaft for '99 LM7 5.3L
I need to know what intake manifolds will fit a 1999 GMC LM7 5.3. I plan on installing a Lingenfelter polished LS-1 intake manifold on it. Will it fit? If not what aftermarket intake manis are available for the LM7?
Old Dec 21, 2003 | 03:02 PM
From what i know Flames...if it will fit on an LS1 it will fit your 5.3...and i know for sure intakes will cuz i have seen more than a few with Z06 intakes..but thats what i know....Hope it helps...
Old Dec 21, 2003 | 07:09 PM
12 Second Club
why would you want to replace the intake on a truck anyways? from what i have heard they are much more efficient than any of the F or Y body intakes...
Old Dec 21, 2003 | 07:16 PM
99Silver6.0's Avatar
The stock 5.3 intake makes good torque. Id leave it alone. Unless somebody can give you some hard core evidence that an AM intake will make good numbers over stock, I wouldnt waste the money. The only intake Id even consider spending money on is that FAST LSX intake which is set up for direct-port N2O injection. Only thing is I dont think it will fit on the 5.3.
Old Dec 21, 2003 | 07:41 PM
The LS6 intake will fit the 5.3 as will any LS1 style intake including the LSX,the only problem with using a intake designed for a F or Y body is the throttlebody location and accessary drive are different from the trucks'.To run any of these you will need to reroute your accessary drive belt tensioner to make space for the lower throttlebody position.The LS6 or the LSX manifolds would probably only show slight hp gain unless they were used with other mods.Unless you are planning major engine mods that move the power band into the 6500 rpm + range I wouldn't even consider a intake manifold change,the expense will far outweigh any gains.
thompson
Dec 27, 2017 06:48 AM
nabozny21
Oct 17, 2015 07:47 PM
wickedRCSB
Oct 10, 2015 09:29 PM
Silver8ado
Sep 30, 2015 11:42 AM
old motorhead
Sep 29, 2015 08:22 PM
