Cams? Heads? Intake & exhaust manifolds?
Old Mar 16, 2003 | 03:39 AM
blacknight02's Avatar
Default Cams? Heads? Intake & exhaust manifolds?
I just wanted to make a post to get some opinions. I have a 02 5.3 sc stepside with AS&M headers, 40 series flowmaster dumped before axel, MAFS, K&N air flow system, Hypertech tuning, and a 2"4" Hotchkis drop. Does anyone have any suggestions on what kind of cam, heads, intake manifolds, or exhaust manifold to go with this set up i have. Or if anyone has anything else to add i would appriate it.
Thanks Trey
Old Mar 16, 2003 | 04:13 AM
GREGGO's Avatar
Default Re: Cams? Heads? Intake & exhaust manifolds?
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif"> or exhaust manifold to go with this set up i have </font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">With AS&M's , not sure what you want here. As far as a cam, depending on how radical you get you may need a stall to get full advantage of it. What goals do you have in mind? Heads, I would go with a min of stage one. That would be oversized valves in the stock seats. Use double springs for a large cam. Chrome moly pushrods etc... That should give you something to chew on. Your stock intake manifold is fine for just about everything. Now if you end up going 400+ci, you may want to look into another intake. But so far, no-one has done an LS6 intake. I was going to try it, but other thing came up.
OHsixLS3
Dec 27, 2016 09:30 AM
GrooveCityZ71
Aug 31, 2015 12:05 PM
steves86ta
Jul 28, 2015 10:21 AM
fat tony157
Jul 16, 2015 12:35 PM
4B11T
Jul 13, 2015 03:48 PM
