Cammed my truck. Now having problems
Old Jul 25, 2012 | 12:27 PM
ivan_key's Avatar
some one said its bc of the ls2 cam gear, but how would i fix this so it will start normal and not throw any codes???
Any ideas???
Also with all these need performance parts I put on and the tune done, the truck doesn't feel like it has any more power and isn't any faster
Old Jul 25, 2012 | 07:49 PM
Byrdman11's Avatar
One thing if u clean codes which one set first?
Old Jul 25, 2012 | 08:00 PM
ivan_key's Avatar
Not sure. I'm about 15 mins away from a place to get my codes scanned
Old Jul 26, 2012 | 03:48 AM
141,161 heater performance codes ie dead heaters
140,160 o2 insufficient activity codes
po36,56 02 heater control circuit.
You fragged a ground, pinched or cut some wires or the tune in your truck is a complete mess
Old Jul 26, 2012 | 06:54 AM
Tootall's Avatar
Originally Posted by ivan_key
some one said its bc the ls2 cam gear, but how would i fix this so it will start normal and not throw any codes
If you used the LS2 cam gear . . . then you have the wrong cam gear. You HAVE to use the LS7 cam gear
Old Jul 26, 2012 | 12:18 PM
ivan_key's Avatar
I was told the later ls2 can gears and ls7 can gears are the same. And the 02 sensors wires are perferct and truck as low miles. So I'm guess it's in the tune some where. Truck still isn't starting worth a ****
Old Jul 26, 2012 | 01:49 PM
Tootall's Avatar
When you're ready to stop blaming your tuner, and believing what an inexperienced person told you. . . . . Suck it up, buy the LS7 cam gear and then you'll have no more issues
Old Jul 26, 2012 | 02:13 PM
AndysC3's Avatar
Did you perform the crank relearn?
Old Jul 26, 2012 | 03:10 PM
ivan_key's Avatar
I'm not blaming the tuner for the cam sensor problem. So I don't know where u mis understood that. I am te inexperienced one and that's why I made this post bc I didnt know where the problem was. I talked to the place that got me the cam sprocket and they did give me the wrong one. So I will replace it with the right one this weekend
I'm saying the o2 sensors could be from the tune or maybe anothe issue. I double checked them
I don't know what a crank relearn is
Once I throw the new ls7 can gear in, besides my problems being fixed will it run better to? Bc it cuts out a bit here in there through out the rpm range
Old Jul 26, 2012 | 03:41 PM
pewterliftedz's Avatar
that should help your cam codes. But idk about those heater codes.
