a cam that would work for me.
Old Jan 16, 2008 | 03:49 PM
95yukonGT's Avatar
Default a cam that would work for me.
so i have a stock 95 gmc yukon gt.it has the 5.7l with the carb fuelinjection system.it is 4wd
mods that follow are:
shotry headers/or longtubes
catless y pipe
custom dual exhaust
intake
computer chip.
Old Jan 16, 2008 | 05:08 PM
sprayed8's Avatar
your gonna have to ask yourself what your really gonna use your truck for.
what kind of sound do you want?
are you willing to run a higher stall converter?
Fuel Mileage?
a lot of guys on here use cams with durations around 220 and lift around .580 and a 112 lsa would give a lot of lope where a 114 will be less agressive sounding.
personally i think i'm going for something for like 224/224 .600/.600 on a 114lsa custom grind.
Old Jan 16, 2008 | 08:06 PM
95yukonGT's Avatar
prolly pulling a future stang down to englishtown,nj.just pulling stuff with a trailer.it is a dd also.fuell mileage is just not to get that bad.a rougher idle.more raspy.just something that sounds nast but willl work for me.
Old Jan 17, 2008 | 01:33 PM
sprayed8's Avatar
your in kinda the same situation as me, but i need the torque not to tow, but to move a heavy truck. i would say try to kep it around 220* duration or lower unless you can spend some money on a good converter and if you want that good sound go with a 112lsa i would call comp cams and ask them about the lift to keep plenty or torque. i was originally thinking that .584 was nice but i have talked to a couple of guys who have had custom grinds with high lift lke i mentioned earlier for that express purpose.
also, i downloaded comp cams software which will tell you what cams they have for you off the shelf based on what you wanna use it for. very helpful. its called CamQuest. i think the download is free right now so i would give that a try. you can find it right on the opening page at
http://www.compcams.com/DefaultWide.asp
Old Jan 17, 2008 | 06:33 PM
95yukonGT's Avatar
where is the 112lsa at al.i already have the comp cams thing so yea.wat is my truvk.hydralic roller or wat.thanks
Old Jan 17, 2008 | 06:48 PM
95yukonGT's Avatar
http://store.summitracing.com/partde...&view=1&N=700+
wat bout this one.would it work for me.a 2000 stall in the future for me also.
Old Jan 17, 2008 | 08:16 PM
budhayes3's Avatar
PT's Slowest Truck
That cam seems a little big for a small block chevy in a heavy tow vehicle IMO. I'd be looking for more torque down low to get that rig moving...something with a little less intake duration.
Remember, this is a SBC, so alot of the common cam recommendations that you see around here go out the window...the majority have GENIII engines
Old Jan 17, 2008 | 08:18 PM
95yukonGT's Avatar
can u guys find me the right one maybe.just help me out a little.looking for something that will help me towing at the same time give me that noticeablle idle like u guys have in ur 5.3l turcks.
Old Jan 17, 2008 | 09:16 PM
dkota1968's Avatar
Try a comp xtreme 4x4 cam, great tourque made for a truck.
Old Jan 17, 2008 | 10:22 PM
00Silv4.8's Avatar
ok well since obviously everyone who has said somethin is running a 00+ dont worry about it unless u look up a specific one out of comp cams catalog. Or go to Vinci, they are a sponsor on the far right of this screen. They have I think 4 cams for the OBS 5.7s. Good luck
