cam valve spring help?
Old May 9, 2004 | 09:08 PM
dubrado's Avatar
Default cam valve spring help?
Looking at maybe a TR220 or TR224 cam or equivilant comp cam
what valve springs will i need?
Do i need new retainers and seats etc...?
just seeing exaclty what i need so i can start pricing
Old May 9, 2004 | 09:46 PM
one03sierra's Avatar
Formerly one92rs
Talking
i think you will need at least 918's. not sure what the lift is. i would get new keepers and hardened push rods. no seats will be needed. and the stock retainers will work. good luck. and get a good tool and some fittings for air in the cylinders. i put on a 12" hose on my fitting and it made it easier.
Old May 10, 2004 | 10:17 AM
BigKID's Avatar
I would recomend either the comp 918 (if you buy used make sure they are blue stripes) or the manley kit from SDPC. Both are good to .600" lift. For the only a few dollars more the manley kit comes with Ti retainers. You do not need new retainers, seats or keepers with these two springs. The springs are made to reuse you stock stuff.
Old May 10, 2004 | 01:54 PM
dubrado's Avatar
why does it have to have the blue stripe? i keep seeing this? what does the stripe mean?
Old May 10, 2004 | 02:18 PM
BigKID's Avatar
The blue stripe marks it as one of the revised 918. A while back Comp had a few bad batches of 918 which would break with lifts well under .600" When they fixed the problem the started marking them with the blue stripes rather than the yellow(I think it was yellow?) they previously marked them with.
Old May 10, 2004 | 03:47 PM
Formerly one92rs
Talking
the comp 918's i just installed were blue striped ones.
chopperloco
Jul 10, 2016 10:45 PM
Jake99
Aug 8, 2015 07:56 AM
bizle
Jul 22, 2015 07:31 PM
4B11T
Jul 13, 2015 03:48 PM
Mzay
Jul 6, 2015 11:05 PM
