cam swap help question
Old Jun 19, 2007 | 09:51 PM
dry_kill's Avatar
Default cam swap help question
ok fellas im going to be taking the cam out my 4.8 this weekend and putting it into the ls1 that i got. my question is what can i do to hold the flywheel in place on the ls1 so i can take the bolt out? it is a longblock but does not have a flywheel, thx fellas
Old Jun 19, 2007 | 10:17 PM
2002C5COUPE's Avatar
are you talking about the crank bolt?
Old Jun 19, 2007 | 10:20 PM
if you have flywheel bolts just screw two of them in halfway, and have a buddy with a pry bar use them as something to hold against while you hit the crank bolt with an impact
Old Jun 20, 2007 | 03:04 PM
dry_kill's Avatar
ok sounds good, thanks
Old Jun 21, 2007 | 07:55 AM
OnyxSilveradoSS's Avatar
I have heard about using a bar thru the front of the pully to brake it loose then remove the bar and finish taking it off. your engine is sitting there or on a stand??
Old Jun 21, 2007 | 09:20 AM
BLACKND's Avatar
What cam you running in the 4.8?
Old Jun 22, 2007 | 10:50 AM
dry_kill's Avatar
its on a stand
the cam is a 226/226 cam, but its gunna be going in the ls1 now
OHsixLS3
Dec 27, 2016 09:30 AM
GrooveCityZ71
Aug 31, 2015 12:05 PM
WICK3DxGATA
Jul 21, 2015 06:59 PM
Aboss
Jul 9, 2015 10:28 AM
