Cam swap gasket question?
When I had mine torn down and could not get the pulley off, I put it back without changing the water pump gaskets. Then raced at Thunder...no leaks. You can reyse any of them as long as they are not flat or torn from the metal when they come out. But they are cheap enough to get the added insurance. When I finally get off this shutdown at work, and get a certain owners manual
, I plan on replacing all of them when I finally get the swap done.
The balancer bolt is a stretch bolt. I believe the torque is something like 24lbft then 120 degrees. Something like that. The bolt is designed to be stretched for proper holding of the balancer. I have seen these bolts walk out if not replaced but some people have luck with not replacing them.
Another question I have is the tool to lock the flywheel so the motor doesn't spin while removing or installing the bolt, whats the part number? Anyone know.
hit i can not answer any # but it is just the same as an f-bod for the t-chain. the oil pump un ported i got from the dealer for 90 something but can get it cheaper at the same dealer and the bolt mud explained it. sorry could not help on any numbers but i think they are in a stick at the top of the forum.
GrooveCityZ71
Aug 31, 2015 12:05 PM
bbowerman
Jul 26, 2015 10:57 PM
