Cam swap gasket question?
Old Dec 9, 2003 | 11:11 PM
Hit Man X's Avatar
Part numbers for:
Balancer Bolt
Timing Chain
Oil Pump
Please.
Old Dec 10, 2003 | 02:11 PM
GREGGO's Avatar
When I had mine torn down and could not get the pulley off, I put it back without changing the water pump gaskets. Then raced at Thunder...no leaks. You can reyse any of them as long as they are not flat or torn from the metal when they come out. But they are cheap enough to get the added insurance. When I finally get off this shutdown at work, and get a certain owners manual , I plan on replacing all of them when I finally get the swap done.
Old Dec 10, 2003 | 02:22 PM
Flyer's Avatar
Whats the deal with the balancer bolt? Why does it need to be replaced?
Old Dec 10, 2003 | 05:40 PM
mudz5.3's Avatar
The balancer bolt is a stretch bolt. I believe the torque is something like 24lbft then 120 degrees. Something like that. The bolt is designed to be stretched for proper holding of the balancer. I have seen these bolts walk out if not replaced but some people have luck with not replacing them.
Another question I have is the tool to lock the flywheel so the motor doesn't spin while removing or installing the bolt, whats the part number? Anyone know.
Old Dec 11, 2003 | 06:14 AM
sleepersilverado's Avatar
hit i can not answer any # but it is just the same as an f-bod for the t-chain. the oil pump un ported i got from the dealer for 90 something but can get it cheaper at the same dealer and the bolt mud explained it. sorry could not help on any numbers but i think they are in a stick at the top of the forum.
Old Dec 11, 2003 | 03:17 PM
Hit Man X's Avatar
Incase someone needs to know:
12557840 - bolt
12552954 - chain
GrooveCityZ71
Aug 31, 2015 12:05 PM
bbowerman
Jul 26, 2015 10:57 PM
WICK3DxGATA
Jul 21, 2015 06:59 PM
4B11T
Jul 13, 2015 03:48 PM
Aboss
Jul 9, 2015 10:28 AM
