Cam shopping again
Old Apr 9, 2004 | 11:41 AM
Flyer's Avatar
Default Cam shopping again
I know ... I'm sure the cam questions are getting old, but here's another one.
How would a 224/230 run in a 5.3? Think it would be to much? It's blown .. so keep in mind that overlap is an issue.
I think I remember RanWalk using it, but that was on either a 6 or a 402 or something considerably bigger than a lowly 5.3.
Any opinions or advice? I'm just not sure if I want to go that big or not.
Old Apr 9, 2004 | 06:22 PM
Flyer's Avatar
Anyone care to chime in ?
This cam have any overlap or anything like that?
Old Apr 9, 2004 | 07:59 PM
Get Compcams to do you a custom grind using XE-R lobes with a 220/228 .581/.588 on a 114 or 115 LSA.That should wake up things with the 5.3 just set your shift points about 6800rpm and keep your same supercharger pulley.
Old Apr 10, 2004 | 02:28 AM
Flyer's Avatar
I'm still running a 3.4 inch pulley.
That's a huge split! Did I mention I'm trying to get some heads for this beast too. Some 6.0 heads with mild p&p on them.
Old Apr 10, 2004 | 02:34 AM
bigguy75inches's Avatar
I think flyer is going for the sound barrier.
Old Apr 11, 2004 | 12:04 PM
Gustin's Avatar
Arrow
You will need a 113 115 lsa. You will have to pull out cam cards to get the lowest overlap or will have to degree it. If you are looking at a cam card just add the two top numbers on the diagram and that will give you your overlap. Good luck.
Sean
all_individual
Oct 10, 2015 10:09 PM
DrX
Aug 19, 2015 04:45 PM
low2001gmc
Jul 23, 2015 05:10 PM
all_individual
Jul 13, 2015 11:01 AM
Aboss
Jul 9, 2015 10:28 AM
