Cam Selection Part 2
Old Jan 27, 2004 | 12:03 AM
Deckhand's Avatar
Default Cam Selection Part 2
Now that I am back in business , I can get a new cam.
What would be the best selection of cams for a lightly modded 4.8L.
I have access to nelson ls1edit tuning, so tuning issues shouldnt be a problem.
Something with a nice amount of torque and strong within the midrange powerband would be ideal. Also would like an aggresive lopey sound to it.
Any suggestions. Id rather not get a custom grind cam, but all comments are welcomed.
thanks guys.
Old Jan 27, 2004 | 12:41 AM
FILE's Avatar
I really like my cam but if I could it again I would go with this one:
216/220 525/532 114lsa
Old Jan 27, 2004 | 01:16 AM
14 Second Truck Club
Go with the one I have , it sounds exactly like what you are wanting.
Old Jan 27, 2004 | 01:17 AM
Flyer's Avatar
Tib ... I wazs just selling one like that! Someone is suppose to send me the money for it this week.
Old Jan 27, 2004 | 05:19 AM
BigTex's Avatar
I'd hold out and see how fast4.8 likes his new cam.
On a 4.8, I'd go with a custom comp something like a XE 210/214 high lift 114sa. If you don't care about low end power, go bigger. Ask Scream about the 212/218 in his 4.8.
Old Jan 27, 2004 | 06:32 AM
FILE's Avatar
Scream got 30 rwhp out his 212/218 in his 4.8 without tuning.
Old Jan 27, 2004 | 08:17 AM
BigTex's Avatar
Right, but how was his low end power? Was he happy with the results and would he have gone larger?
Old Jan 27, 2004 | 08:32 AM
Deckhand's Avatar
I was looking at the crane cam site, and it was saying the rpm range was from like idle - 5200?
how does it perform/sound in your application?
thanks bud
Old Jan 27, 2004 | 08:41 AM
Scream's Avatar
MOOBIES Moderator
The low lift 212/218 in my truck was down on low end power. I did, though, have the stock converter and 3.42 gears. The truck didn't lope too bad, and was driveable w/o tuning.
The only thing about running this cam w/o tuning is that you can't rev it all the way to 6500. I picked up 0.3-0.4 in the 1/4 just from upping my shift points to 6500. Should you do that with stock rod bolts? Probably not. But, that little 4.8 would RIDE OUT from a 60 roll. Ran a couple of LT1 Z28s from high rolls and hung with them pretty good.
All in all, I think that the 212/218 low lift is a good cam that will get you results without REQUIRING tuning, but should really be tuned to get the most out of it. I'm sure that the larger cams will require tuning.
Old Jan 27, 2004 | 08:42 AM
Scream's Avatar
MOOBIES Moderator
just for the record...I would LOVE to see someone put a TR220 in a 4.8!
