Cam selection help
Old Nov 18, 2007 | 11:03 PM
Jessica's Avatar
Restricted User
Originally Posted by Qatar
Hello
What do you think of this cam in GMC sierra 4.8L with manual transmutation
Duration @ .050’’ 207 /220
Lift 571" /578
Lobe Separation: 118.5
Now I am running K&N intake and tune
Will I have a good power and how about the drivability. Plecae help me.
Thanks
Take that same cam and drop the LSA about 6-10 and you will have something then
Old Nov 28, 2007 | 06:00 AM
Qatar's Avatar
Registered User
guys I am going to buy that cam
Lift: .525/.532''
Duration @ .050'': 216°/220°
RPM Range: 1300-6300
Lobe 114°
what should I buy with it like valve springs and pushrod?
I would be fine with the yellow valve springs
plz post some reply
Old Nov 28, 2007 | 08:17 AM
ap2002's Avatar
Lift: .525/.532''
Lobe 114°
plz post some reply
very good choice, I like that cam for a mild 5.3, has more lope than the 212/218 and does real good as well, yes you will be ok with the yellow LS6 springs, get you some hardened pushrods 7.400
Old Nov 28, 2007 | 12:12 PM
SlvrSierra4.8's Avatar
It's an excellent daily driver with a noticeable improvement over stock, that doesn't require a high stall converter. Prior to the cam swap, my truck ran 16.5@81.7 mph with bolt ons and 33" tall tires. After swapping in the cam, and a tuned 02 PCM I ran 15.6@89.5mph....almost a whole second and 8 mph gain. Not too shabby IMO. Only place I didn't really gain was my 60' times...they went from 2.5,2.6ish to 2.4-2.5ish. I'm sure that the 33" BFG All Terrains had something to do with that. A mild converter would definitely help also, but isn't necessary for my daily driven needs The cam sounds almost stock too...a trained ear can tell that something's been done though.
Almost forgot, since the cam is so mild, I'm running LS6 valve springs, which allows me to just get in, turn the key, and go, with no worries about having to let the valve springs get some heat in em. Also, I can probably run the springs for the life of the truck with no worries
budhayes3: Any chance you have a soundclip of your truck? Looking at the same cam for my 4.8. Just trying to decide between a 112, 113, or 114 lsa?
Old Nov 28, 2007 | 12:25 PM
budhayes3's Avatar
PT's Slowest Truck
Sorry man, no sound clip...but my camera does record small videos, so I'll see if I can work something out by the weekend.
FWIW, I'd recommend the 114 lsa for ease of driveability and tuning, although the duration is small enough that there's not a whole lot of overlap.
Old Nov 28, 2007 | 02:01 PM
That would be awesome man. Thanks for the input on the LSA as well
Old Nov 30, 2007 | 03:37 AM
Qatar's Avatar
Registered User
thanks for reply. With this cam I will loes the drivebility of the truck, I am running a manual transmission.
Old Dec 2, 2007 | 09:47 PM
budhayes3's Avatar
PT's Slowest Truck
Well, the weekend was buzy and hectic, and needless to say, I didn't get the chance to get a vid clip. I actually tried to squeak it in, and when I went to start recording, the battery in the camera was dead
Maybe I can try to find some spare time during the week...sorry again guys
stock48
11
Aug 18, 2015 05:55 AM
lawhitediamante
Aug 12, 2015 12:14 PM
steves86ta
Jul 28, 2015 10:21 AM
WICK3DxGATA
Jul 21, 2015 06:59 PM
projectnightcrawler
Jul 19, 2015 11:30 PM
