Cam recommendations
2004 RCSB, 5.3, long tubes/exhaust.4l80,4000 stall, currently 3.42,but going with 4.10 soon. 29" tire. I have a btr stage 3 truck cam (218/224 .553/553 114. Looking for more.also switching to NNBS intake soon also. Occasionally run 100-150 wet shot.
It is big but I love it. Goes into lock up about 35mph. I stalled it high because of the longer first gear, but again, going 4.10 anyway. Stock 862 heads, have a set of 243 but they need a full run through before I can use them., shift points are at 6200 right now, will have it shift wherever it's most effective.i don't mind rougher idle. And yes it's my daily lol. I don't drive far to work, and next year I will live closer
With the converter you currently have you could definitely go a bit bigger on the camshaft. I still would be very mindful of the fact that it is still a heavy truck intended for daily use. If you are looking for a little more power and sound I would consider something like a 224/228 on a 112LSA to get you a little more power and sound.
