cam questions (search has been done)
Old Nov 3, 2008 | 11:16 PM
muddychevy98's Avatar
Default cam questions (search has been done)
Ok, i have been doing some research about cams but still need some help, i have read a ton of threads on here and ls1trucks.com and i'm trying to find a decent cam to put in the truck. Now i'm not trying to just stuff the biggest cam in the truck i can as i have seen a lot of people ask about or huge gains anywhere. I am looking for something a little better then the stock cam though with a little bit of a lope to it. So i have been on a couple different sites looking and here are some i am thinking about, but i need a little help also, here are some that i think will work for me so far, thanks in advance:
Cranecams: 1449041
GOOD DAILY DRIVER, STOCK TO SLIGHTLY MODIFIED 4.8L THRU 6.0L, GOOD FUEL ECONOMY, LIGHT CHOPPY IDLE, LIKES HIGHER ROCKER RATIO, NEEDS NO TUNING - RPM RANGE 1800-6000. 551 / 551 210 / 218 114*
http://www.cranecams.com/newproducts...8B/PP0808B.pdf
GM Performance 12480033 - GM Performance Parts Gen 3 Hot Cam Kits - summitracing.com
or but can't find the specs on this one
COMP Cams: Thumpr™, 275THR7 <br>High Performance Street, Stock, Choppy/Thumping Idle
Old Nov 3, 2008 | 11:19 PM
RandomHero's Avatar
Comp 212/218 high lift. Are you sure you searched. I bet I could find 10 threads in less than 5 minutes that ask the same question as yours. If you did search, then more power to you.
Old Nov 3, 2008 | 11:25 PM
yeah i read threads all day, but everybody wants to FI later down the road or something along those lines.
Old Nov 3, 2008 | 11:29 PM
RandomHero's Avatar
Took me 3 minutes to find these
https://www.performancetrucks.net/fo...light=good+cam
Stainless Works
Nov 20, 2015 08:55 AM
MS3Z
Jul 30, 2015 06:17 PM
bbowerman
Jul 26, 2015 10:57 PM
WICK3DxGATA
Jul 21, 2015 06:59 PM
4B11T
Jul 13, 2015 03:48 PM
