cam questions for 5.7 vortech
Old Dec 30, 2004 | 01:16 AM
haulass350's Avatar
awesome you need to send me your entire picture album you have pictures of everything thanks for the part number also, gonna have to order one of those
Old Dec 30, 2004 | 01:26 AM
Mr. Sandog's Avatar
James is good about chronicling his exploits. He must have quite a multimedia library.
Old Dec 30, 2004 | 03:02 PM
86SWB's Avatar
What are you doing with your stock Vortecs?
Old Dec 30, 2004 | 03:08 PM
haulass350's Avatar
prolly gonna toss them on ebay or stick them in the garage if nobody wants to buy them
Old Dec 30, 2004 | 03:13 PM
86SWB's Avatar
If they are for a 350, How much?
Old Dec 30, 2004 | 03:18 PM
haulass350's Avatar
lemme think on it and i'll get back to you
Old Dec 30, 2004 | 05:06 PM
Stroker 1500's Avatar
i have a set of vortecs.... they have 80k on them, and i had no smoke on startup or anything and then i spun a rod bearing and i also lost part of a spark plug in the cylinder, there is the slightest nick on one of the valve seats on mine but i don't think its enough to cause any problems... but a simple valve lap would take care of it... I also have a set of stock valves, aftermarkets springs, and valve seals for the vortec heads
Old Dec 30, 2004 | 10:10 PM
haulass350's Avatar
$250 for my set of heads, complete rockers and everything
Old Jan 10, 2005 | 11:53 PM
haulass350's Avatar
Originally Posted by James B.
They also sell an adjustable pushrod that is a tool you can use to get the contact pattern of roller-to-valvestem perfectly dead-on. The correct length pushrods needed can be read from the tool. I strongly suggest picking one of those up, proper valvetrain geometry will get you the most lift with the least amount of work and make your stem seals last longest. Keep in mind that depending on the patterns of the cam you may need two different length pushrods to make it right - one for the intakes and one for exhausts. The correct adjustable pushrod tool is the one that covers the 7.120" ballpark.
if i was using comp lifters, roller rockers, and cam would they know what size lenth to use? i cant afford to have my truck down for more then 1-2 days due to work and school and wnat every single part there when i tear this thing apart, having it down for 2 weeks waiting on pushrods to come in it NOT and option.
Old Jan 11, 2005 | 12:23 AM
James B.'s Avatar
No need to replace the stock lifters, they are capable of a GREAT DEAL more than what's asked of them in the production L31.
Your only shot at someone knowing the correct size would be if every component of the valvetrain, including the cam, was from the same company. And even then the head gasket thickness is important.
Honestly, if this is your daily driver and you depend on it that much, don't **** with it. You are not in a position to go down this road. Anyone else on this forum also getting twice the stock power out of their smallblock can also tell you about the downtime that goes along with it. Stuff will break. If you need your truck there every day ready to roll you're making a serious mistake with the performance crap.
