Cam questions
Old Feb 20, 2003 | 12:29 AM
Jonezy's Avatar
Default Cam questions
GOing to put a cam into my A4 2500 with a 6.0. What cam should i go with. And what else do i need to make it run right. any imput would be appreciated.
Old Feb 20, 2003 | 05:51 AM
BigTex's Avatar
Default Re: Cam questions
You have a couple of choices: The off-the-shelf comp 212/218 cam would probably be fine. It seems to keep most of the low end power yet pull hard to the redline. It has low lift and easy ramps. OR Get a custom ground cam with faster ramps and more lift, but keep the duration numbers down. That will help you make more power and keep the torque strong. Get either cam on a 114 LSA and have 4* of advance ground in.
Denali08
Aug 9, 2015 04:34 PM
Jake75
Aug 5, 2015 01:26 PM
USMCvet0311
Aug 1, 2015 07:45 AM
bbowerman
Jul 26, 2015 10:57 PM
WICK3DxGATA
Jul 21, 2015 06:59 PM
