Cam PSring Swap in Progress. ?'s on break-in
Old Mar 6, 2004 | 12:24 AM
Talking Cam & Spring Swap in Progress. ?'s on break-in
In the process of installing my Comp cam and z06 springs (see sgi). Anything I shoudl watch for, or any guidlines that need to be followed on the break-in periods of my new top end? I've heard to let the engine warm up before rompin on it or you can break a spring...any info. fact or opinion is welcome because I don't wanna f' anything up!!! I'm running Castrol right now and will prolly change over to Mobil one 5w30 after 3000 miles, I was told this was the break in period..correct?
THANKS!!! I'll let ya'll know how it runs on Sunday!
Old Mar 6, 2004 | 12:47 AM
BigTex's Avatar
You'll need to let it idle for several minutes just to get the coolant back to normal levels. After its warmed up and coolant is full, take it for a several mile drive. Vary the rpms some and watch you temp and oil gauges. Stop and check the levels. If everything is good and sounds right, give it hell.
Old Mar 6, 2004 | 01:12 AM
Flyer's Avatar
These cams are rollers ... there aren't any break in's for rollers to speak of. Just make sure all your fluids are good. I always let mine sit and idle for a while before I test drive it. I will let it sit and idle with the coolant lid off until it gets up to operating temperature, filling as needed, then a little longer just to make sure. After that, put the cap on and let it build up pressure to make sure nothings leaking. Then give it a road test.
Old Mar 6, 2004 | 01:33 AM
Ryan23silverado's Avatar
heat cycle the valvesprings twice before you blast
Old Mar 6, 2004 | 09:10 PM
Thanks for the info guys! Actually, a friend of mine who is a gearhead mechanic is doing the swap, so he should be right on the money on those suggestions. I was just inquiring for my benefit when I get the truck back. THANKS!!!
OHsixLS3
Dec 27, 2016 09:30 AM
GrooveCityZ71
Aug 31, 2015 12:05 PM
WICK3DxGATA
Jul 21, 2015 06:59 PM
Aboss
Jul 9, 2015 10:28 AM
GreyChevy
Jul 7, 2015 08:57 PM
