cam for more torque or something else
Old Oct 1, 2002 | 01:01 PM
99Z71's Avatar
Default cam for more torque or something else
what would be a good cam that would offer more or equal tq than hp and still let the truck have the same programming. If there is no such cam what bolt-ons would make my slow *** truck quicker (NO NO2).
By the way the truck is:
99' Chevy EC Z71 4.8L with an intake, exhaust, HPP, TB Spacer, JBA power Cables and tr55 plugs, and a de-screened maf
<img border="0" alt="[Truck]" title="" src="graemlins/gr_truck.gif" />
Old Oct 1, 2002 | 08:52 PM
99Z71's Avatar
Default Re: cam for more torque or something else
will someone please help!!!!!! . <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" /> <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Old Oct 1, 2002 | 09:17 PM
BigTex's Avatar
Go here:
http://www.compcams.com/catalog/088_089.html
At the bottom, there are 3 cams listed for the LS1. The uppermost cam will be the one.
Also here:
http://www.cranecams.com/master/apps/chevy72.htm
Again, the top choice.
I would prefer the larger lift of the comp, but I don't think I'd want the 112 LSA on it. On the otherhand, the crane is lower lift with a 114 LSA. Those two are "boxed" items available from retail chains. You could get a custom ground cam for a little more money, that would give you more of what you want.
The larger the duration numbers of the cams, the higher the powerband will be in rpms, in trade for low end power. Stick with smaller durations. You might think about getting more lift to assist filling the chambers if you go with short durations. If you go above .500 lift, you will need new valve springs. Personally, I'd change the springs even if you go with the cranes .500 lift.
I think you will see gains with either cam, mainly in the mid - upper range. Its real hard to get stump pullin torque out of a 4.8 without a power adder.
Richard
noproblems209
Aug 10, 2015 06:57 PM
OLD BULL
Aug 1, 2015 05:00 PM
Matt331
Jul 26, 2015 09:40 PM
GM1697
Jul 20, 2015 08:41 AM
07NBSChevy
20
Jul 8, 2015 07:27 PM
