cam installed, wont idle when warm
Old Mar 7, 2010 | 07:32 PM
01SilvyZ71's Avatar
haha noo i knew it would need a retune just i didnt know it wouldnt stay running i figured it'd just run like hell haha
but im 17 i've been sweating this whole weekend praying to god that nothing would go wrong and holy **** i did it!
high five for me
Old Mar 7, 2010 | 07:34 PM
Truckshop's Avatar
you can turn the throttle stop up also. temp fix till a retune
Old Mar 7, 2010 | 07:38 PM
01SilvyZ71's Avatar
ill look into that thanks.
also i noticed there seems to be alot more noise where the rockers are. is that normal or should i check it out after the break in period and retighten everything?
Old Mar 7, 2010 | 07:42 PM
00ChevyScott's Avatar
Wearin' da big hat
What springs did you install?
01SilvyZ71's Avatar
ls6 yellow springs
Old Mar 7, 2010 | 07:56 PM
sonoma43's Avatar
What cam did you put in? did you go to hardened pushrods?
Old Mar 7, 2010 | 07:59 PM
01SilvyZ71's Avatar
specs are 210/216, .532"/.532", 110* and 7.4" hardened rods.
Old Mar 7, 2010 | 08:01 PM
sonoma43's Avatar
as long as you got the rockers torqued to 22 ft./lb. you should be good.
Old Mar 7, 2010 | 08:04 PM
01SilvyZ71's Avatar
well i did that sooo i guess im good. thanks for the help man and ill be sure to get sound clips one of these days
Wearin' da big hat
Did you torque them, then turn the motor over 180deg by hand and retorque them?
