cam install question
Old Mar 18, 2004 | 06:59 PM
slow4.8's Avatar
Default cam install question
is it necessary to remove the heads to install a cam or does the pen magnet to hold the lifters trick really work? thanks for the info
Old Mar 18, 2004 | 07:03 PM
No, you don't need to remove the heads. Yes, the pen magnet thing really does work. Refer toLS1howto.com for reference. Check out their cam install tech articles. They're on f-body cars, but pretty much all is the same.
Old Mar 18, 2004 | 07:04 PM
FILE's Avatar
I had several people wanting to remove the head on my 5.3 to instlal my cam... I just moved on untill I found some one who did not remove my heads.
Old Mar 18, 2004 | 07:05 PM
BlownChevy's Avatar
blownerator
25 Year Member
Old Mar 18, 2004 | 11:36 PM
Hell, foget spengin the $$$ on the magnets and still having the, however slight, possibility of dropping a lifter or hanging a magnet or something else and buy you a 3' section of 5/16" steel rod. Taper the last 5/8" of each end to a point, the other end bends up, the last inch or so, for a handle and you're coocking with gas!!!!!!!!
Old Mar 18, 2004 | 11:40 PM
Flyer's Avatar
I ended up pulling the heads on mine.
I had an old POS pen magnet trying to check the lifters being pulled up, and the tip broke off in the lifter bore. Passed that, yes, the magnets really work though, don't skimp, buy new ones.
The_W
Oct 28, 2015 09:00 PM
all_individual
Oct 10, 2015 10:09 PM
WICK3DxGATA
Jul 21, 2015 06:59 PM
FlowmasterMufflers
Jul 17, 2015 03:26 PM
all_individual
Jul 13, 2015 11:01 AM
