Cam Install
Old Apr 21, 2006 | 03:19 PM
RedChevy4x4's Avatar
Default Cam Install
Other than the cam, valve springs, and pushrods what else is needed to do a basic cam install?
Old Apr 21, 2006 | 03:22 PM
thunder550's Avatar
High on diesel fumes
Check out this article - it's for an F-body but it's pretty much the same for trucks.
http://www.ls1howto.com/index.php?ar...952c9b119576e8
Old Apr 21, 2006 | 05:44 PM
budhayes3's Avatar
PT's Slowest Truck
Gaskets (SDPC sells a cam swap kit, complete with crank bolt), coolant, a little RTV for where the timing cover meets the oil pan in the corners...the necessary tools, etc. Some guys re-use their gaskets, but replacing them is cheap insurance against having to pull things apart twice. If the vehicle has higher mileage, a new oil pump and timing chain isn't a bad idea either.
Old Apr 21, 2006 | 08:33 PM
Got all that covered. Thanks.
Old Apr 22, 2006 | 07:06 PM
agreif's Avatar
Do you have a link to this, I searched all around their site and couldn't find it?
Andrew
Old Apr 22, 2006 | 07:20 PM
kbracing96's Avatar
I got a gasket kit and bolt I'd sell if your intersted. PM me
Old Apr 22, 2006 | 11:30 PM
budhayes3's Avatar
PT's Slowest Truck
Andrew
Here ya go: http://www.sdpc2000.com/catalog/2721...3-LS1-LS6-.htm
Camshaft installation kits include intake valve cover gaskets, timing cover gasket, water pump gaskets, front cover gasket, front cover seal and a new balancer bolt.
Price: $44.95
Part # KITSD51902
Old Apr 23, 2006 | 08:06 PM
agreif's Avatar
Thanks for the link, the one place I didn't look far enough.
"Camshaft installation kits include intake valve cover gaskets, timing cover gasket, water pump gaskets, front cover gasket, front cover seal and a new balancer bolt."
I though the timing cover and the front cover were the same thing?
Andrew
Old Apr 23, 2006 | 08:19 PM
budhayes3's Avatar
PT's Slowest Truck
Andrew
No problemo
Yea, I think there's a few typo's in there...1) "intake valve cover gaskets" (it just comes with valve cover gaskets, not sure why they mention intake, which doesn't get removed when doing a cam swap on a genIII 2) "timing cover gasket and front cover gasket" is redundant, like you said they're both the same thing. Even with the typo's though, I got my gasket set from them when I did my cam swap and everything I needed was right there (except for the cam and springs of course...now that would be a geat deal for 45 bucks!! )
all_individual
Oct 10, 2015 10:09 PM
low2001gmc
Jul 23, 2015 05:10 PM
Offroadunleashed
Jul 20, 2015 02:25 PM
ssierra08
Jul 15, 2015 06:40 AM
all_individual
Jul 13, 2015 11:01 AM
