Cam Install
Check out this article - it's for an F-body but it's pretty much the same for trucks.
http://www.ls1howto.com/index.php?ar...952c9b119576e8
Gaskets (SDPC sells a cam swap kit, complete with crank bolt), coolant, a little RTV for where the timing cover meets the oil pan in the corners...the necessary tools, etc. Some guys re-use their gaskets, but replacing them is cheap insurance against having to pull things apart twice. If the vehicle has higher mileage, a new oil pump and timing chain isn't a bad idea either.
Andrew
Originally Posted by agreif
Do you have a link to this, I searched all around their site and couldn't find it?
Andrew
Andrew
Camshaft installation kits include intake valve cover gaskets, timing cover gasket, water pump gaskets, front cover gasket, front cover seal and a new balancer bolt.
Price: $44.95
Part # KITSD51902
Thanks for the link, the one place I didn't look far enough.
"Camshaft installation kits include intake valve cover gaskets, timing cover gasket, water pump gaskets, front cover gasket, front cover seal and a new balancer bolt."
I though the timing cover and the front cover were the same thing?
Andrew
Andrew
Andrew
Andrew
Yea, I think there's a few typo's in there...1) "intake valve cover gaskets" (it just comes with valve cover gaskets, not sure why they mention intake, which doesn't get removed when doing a cam swap on a genIII 2) "timing cover gasket and front cover gasket" is redundant, like you said they're both the same thing. Even with the typo's though, I got my gasket set from them when I did my cam swap and everything I needed was right there
(except for the cam and springs of course...now that would be a geat deal for 45 bucks!!
Offroadunleashed
Jul 20, 2015 02:25 PM
all_individual
Jul 13, 2015 11:01 AM
