CAM help
Old Mar 3, 2008 | 11:11 PM
RandomHero's Avatar
Originally Posted by Yellowsierra
I know you may lose some low end torque with a big cam.....
That is a bit of an understatement for the cam you suggested. That cam won't make power till at least 3500rpms(probably closer to 4000) in a 4.8L
Old Mar 3, 2008 | 11:59 PM
Yellowsierra's Avatar
I bet he will go with alot bigger of a cam than a 220! Hey dusty it wouldn't be a bad idea to shave the heads to bump the compression up. They only have around 9.6-1 compression. We could check the piston to valve clearence to see how much we could safely shave off. It would be nice to get that motor to 10.5 to 11- 1! That would wake it up alot!
My GTO motor is 10.9-1 and If I bought a set of heads I would like to get close to 12-1! Vengeance racing has been tuning 12-1 motors to run on pump gas. It really bumps the Torque up!
Old Mar 5, 2008 | 07:31 PM
dusty4.8's Avatar
yeah that would be sweet if it all worked out right guess i just need to call vengance and see what all they say, thanx gator see yall friday
Old Mar 6, 2008 | 07:37 PM
Ok i've thought long and hard on a cam for your truck. I came up with this grind. 360/360 dur. 673/642 lift 108LSA. It should be plenty big enough but may lose alittle gas mileage!
Old Mar 7, 2008 | 04:25 PM
dusty4.8's Avatar
u dont think thats too big
2500ZL1
Jan 25, 2016 06:30 AM
lawhitediamante
Aug 12, 2015 12:14 PM
steves86ta
Jul 28, 2015 10:21 AM
WICK3DxGATA
Jul 21, 2015 06:59 PM
projectnightcrawler
Jul 19, 2015 11:30 PM
